Author Topic: [SHIPPED] PCB Mount Clear Switches  (Read 36274 times)
Offline ekw808
  • Ekw
Re: [IN TRANSIT] PCB Mount Clear Switches ETA 10/11
« Reply #100 on: Mon, 08 October 2012, 22:19:46 »
They will be arriving tomorrow, and I will try to get them all out by the end of the week.
[One Keyboard at a time]
Offline remmeh
Re: [RECEIVED] PCB Mount Clear Switches
« Reply #101 on: Tue, 09 October 2012, 21:54:04 »
just got shipment notification!
Offline theultrazord
« Reply #102 on: Wed, 10 October 2012, 00:44:36 »
I got my notification too. Freaking fastest groupbuy ever.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #103 on: Wed, 10 October 2012, 01:30:56 »
This seems quite cheap. when is the next GB for this?
SmallFry! <3
Offline ekw808
  • Ekw
Re: [SHIPPED] PCB Mount Clear Switches
« Reply #104 on: Wed, 10 October 2012, 08:05:48 »
Group buys aren't run on a daily basis, and there is no system for it. If someone wants to run one, then it happens, if not then it doesn't.
Check paypal for shipping information.
Offline fl0w3n
« Reply #105 on: Fri, 12 October 2012, 19:48:08 »
Got mine today, awesome! Thanks.  Might have been short 1, but I also might have mis-counted.  No biggie.
Thanks again ekw for running this.  I'll leave some Heat!
« Reply #106 on: Fri, 12 October 2012, 19:56:28 »
Got mine! Again thanks a ton for doing this.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #107 on: Fri, 12 October 2012, 22:43:53 »
Also got mine, 100 on the dot. Thanks a ton.
Offline BoxWithADot
« Reply #108 on: Sat, 13 October 2012, 09:39:44 »
Got mine! Thanks a lot ekw!
Offline shawn o
« Reply #109 on: Sat, 13 October 2012, 17:23:35 »
Me too, thanks!
Offline eyesmiles
« Reply #110 on: Sat, 13 October 2012, 19:55:51 »
 All 110 came in. Thank you ekw808!
Offline WRXChris
« Reply #111 on: Sat, 13 October 2012, 20:06:34 »
mine arrived yesterday, thanks again ekw!
Offline cgbuen
    • cgbuen.io
Re: [Taking Orders] PCB Mount Clear Switches
« Reply #112 on: Sun, 14 October 2012, 22:37:50 »
metalliqaz you can just snip the stabilizing pins off these switches to make them platemount
Thanks for sharing.. had I known this little bit of info earlier, I might have tried to jump on this GB. Maybe next time!
