Author Topic: Are clear stems the same as gray stems?  (Read 1690 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Wed, 03 October 2012, 19:57:02 »
Are clear stems the same as gray stems? I have a bunch of clear stems and one gray stem, the clear feels slightly more tactile  than the gray but the stems look identical in terms of the bump.
« Last Edit: Wed, 03 October 2012, 19:58:47 by The_Beast »
Re: Are clear stems the same as gray stems?
« Reply #1 on: Wed, 03 October 2012, 20:02:36 »
I was wondering the exact same thing a few weeks ago.
« Reply #2 on: Wed, 03 October 2012, 21:51:57 »
Grey stems can be the same as black/red stems, depending on the grey switch in question.
I'm pretty sure the grey is the same as clear. Sometimes other factors can make them feel different, though.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Wed, 03 October 2012, 21:53:30 »
It's light gray tactile, not a dark gray linear
The only difference was that the gray was on the spacebar and the clear was on the right alt. But both were using brown/red/blue springs.
