Author Topic: Suggestions for Advantage keyboard  (Read 662548 times)
Offline pnutster
Re: Suggestions for Advantage keyboard
« Reply #250 on: Tue, 30 December 2014, 22:29:24 »
Any update on the likely release date for this? Id like to get a column-aligned keyboard, and I think the kinesis would be most suitable for me. Still, I don't want to invest in one and have a new improved model released the next day (or even month!).
Re improvements: maybe a lower profile, and some sound damping or stiffening to make it quieter.
I prefer a single-piece keyboard for convenience and a tidy desk, and that would keep costs down too I guess.
As far as I know, the latest known is still "Early 2015". Eager to buy my 2nd Kinesis Advantage, but same as you describe, don't want to order now knowing a new release is coming soon. As far as I read with real function keys!!!
Kinesis Advantage
Logitech Cordless Trackman FX Optical Trackball
Apple TrackPad
Offline yirimyah
« Reply #251 on: Tue, 20 January 2015, 18:31:59 »
+1. Would like to get an Advantage but this close to release date I'm going to hold off.
Also, your FreeStyle Blue would be a fantastic keyboard if you hadn't put rubber domes on it.
Offline highend
« Reply #252 on: Thu, 19 February 2015, 15:02:56 »
Any official statement about the status of the development of the new Advantage?
Offline pnutster
« Reply #253 on: Thu, 19 February 2015, 15:28:17 »
I contacted Natas206 not so long ago.
Hi! Sorry for the lack of updates. We had a few hurdles with the new firmware that we finally solved, so we've made tremendous amount of progress just in the past few weeks alone. We are getting closer! Still no ETA though, but beta testing should start soon.
Kinesis Advantage
Apple TrackPad
Offline highend
« Reply #254 on: Fri, 20 February 2015, 04:04:22 »
Thanks pnutster for posting that information. I hope the new version will be worth it's money...
Offline ogregev
« Reply #255 on: Fri, 20 February 2015, 08:23:35 »
May I join the beta testing? My advantage I've been using for a year with my magic trackpad (clicky!) mount modification to prove my worthiness.  :)
I used dashgrip and cut a piece of plastic to hold the trackpad so I can still use the clicky feet of the trackpad. Purposefully place near to the left side so my left hand can reach it without stretching out too much. Changed thumb cluster top keys to flat keys to make more room for the trackpad.
album: http://imgur.com/a/IL8ve
Here is my variation on that theme.  I had an aluminum plate machined to the same size as the Magic Trackpad.  I applied a layer of velcro to the rounded front edge of the trackpad and left the rear edge floating.  The front velcro acts as a hinge allowing the rear buttons under the pad to press on the plate.  Lastly, I velcroed the plate to the keyboard.
Offline nimrod01
« Reply #256 on: Fri, 20 February 2015, 08:31:57 »
I'm another waiting on feedback on the new release.  I recently have my Advantage die on me and something I'd really like is more substantial function keys... And well, after seeing this thread, I'm not go order one until further news on a refresh of this keyboard.
Offline natas206
  • * Commercial Vendor
« Reply #257 on: Fri, 20 February 2015, 12:17:40 »
What's wrong with your current keyboard? Often times there are easy fixes to get it working again (replacing the USB cable, firmware chip, etc.). It's worth contacting tech@kinesis.com to see what we can do.
As for the updates... sorry guys still tight lipped for now. As pnutster pointed out, we're hoping to start beta testing soon (within 1-3 months).
Offline ElectronicFur
« Reply #258 on: Wed, 04 March 2015, 15:14:22 »
Oh, good to hear it's getting close to release.
Does anyone know if this new keyboard has bluetooth, or if it's easy to mod the old one to have bluetooth?
Kinesis Advantage Pro (silver) | Kinesis Advantage (black) | Microsoft Natural Elite | Ergodox (on order)
« Reply #259 on: Wed, 04 March 2015, 18:09:24 »
When you do, see what happens when you hold down seven keys at once. ;)
Offline uberben
« Reply #260 on: Wed, 04 March 2015, 22:16:18 »
I'm working on a replacement controller for the old Kinesis that does bluetooth. It is probably still a few months away, but it is coming.
Offline natas206
« Reply #261 on: Mon, 09 March 2015, 18:50:35 »
Is there a good reason for needing more than 6 + modifier keys on an ergo keyboard?
« Reply #262 on: Tue, 10 March 2015, 08:16:38 »
That sounds great. I take it that it's not straightforward to add bluetooth to the Advantage then?
Cheers,
Menno
Offline uberben
« Reply #263 on: Tue, 10 March 2015, 08:28:03 »
Well, there is the easy route of buying a USB to bluetooth adapter and shoving it inside the case, but I'm hoping to add some other features to my board. The pcb will allow for adding extra switches and I plan to add a trackball and/or trackpoint, among other things. I'm also hopeful that my board will have better battery life as I have control over how the thing sleeps, but software will be the last piece of the puzzle.
Offline mannelig
« Reply #264 on: Sat, 14 March 2015, 03:31:32 »
Wow, that would be great for upgrading old Advantages after new will come out. I hope you'll succeed (and hope to buy one kit)!
Kinesis Advantage review in Russian:
http://habrahabr.ru/post/146353/
Offline goflo
« Reply #265 on: Tue, 24 March 2015, 11:40:43 »
Time keeps ticking away....
Any news yet?
Is it possible to be a part of beta testing?  ;D
- Ergodox Classic/Browns/Grifiti Rests  | - IBM Model M Blue Label |  - Poker II MX Blue | - Ergodox Classic/Blues/Grifiti Rests
Offline Canut
« Reply #266 on: Wed, 01 April 2015, 10:34:07 »
And as April 1st rolls by again... one more lap around the Sun.
95933-0
Offline againer
« Reply #267 on: Sat, 04 April 2015, 15:47:25 »
My wish list: (and the reason why I got a ergodx instead of a kinesis)
F- Keys with cherry mx switches
fully programmable custom firmware
split design
option for blue and clear switches too, not only brown and red switches
and white blank keycaps would look really hot on a black  kinesis
Offline Input Nirvana
« Reply #268 on: Sun, 05 April 2015, 14:50:51 »
R.I.P.
Spock was the bestest
« Last Edit: Sun, 05 April 2015, 14:53:43 by Input Nirvana »
Offline user888
« Reply #269 on: Wed, 08 April 2015, 12:52:21 »
I expect:
  • Same unchanged design (maybe the logo moved)
  • In-house made internals (electronics and firmware), resulting in better and more flexible programmability of layers
  • Rubber F-keys replaced with Cherry ML switches
I really do hope to see at least two extra keys left and right below the shift keys.
Offline jacobolus
« Reply #270 on: Wed, 08 April 2015, 18:43:10 »
I expect [...] Rubber F-keys replaced with Cherry ML switches
Why do you expect that? Why would they use ML instead of MX? They’re not really pressed for space.
Offline natas206
« Reply #271 on: Mon, 13 April 2015, 11:46:24 »
Offline pnutster
« Reply #272 on: Fri, 01 May 2015, 17:45:00 »
Tempted to get the 25% off on Massdrop: https://www.massdrop.com/buy/kinesis-advantage?mode=guest_open if it weren't for the fact that the new Kinesis Advantage is looming around the corner.
Do you see the new Kinesis coming out in 3-4 months from now? I know you can't give any ETA, but hopefully you are able to say if it is going to happen within 3-4 months or not...
Kinesis Advantage
Apple TrackPad
Offline automator
« Reply #273 on: Sat, 02 May 2015, 10:38:02 »
The lack of updates on this frustrating at best.  I think if there was a definite release date by now we would have heard it, as it is I've not even seen any rumors of a beta release so I would not get my hopes up.  Keep in mind this is a company that is not known for moving fast; I'm typing right now on a 15 year old model (maybe more, it actually has an AT connector) that is by no means the first model they made, and it is virtually identical to the new ones.  When I got this keyboard, my computer had 64 MEGS of ram, and that was a lot!
As I think I expressed previously, bring me a mechanical, grid, contoured keyboard with true split and sufficient modifier keys and you can name your price.
Me, on the other hand, despite the old keyboard in front of me now, my life moves fast.  This whole keyboard thing could be a lot of enegry I shouldn't be wasting.  I'm really starting to think I should put my 2 kinesis at the curb, forget I ever heard of alternative keyboards or ever learned Dvorak.  Like learning to play the saxophone, wasted time for a useless skill I'm now embarrassed to carry.
« Reply #274 on: Sat, 02 May 2015, 11:27:31 »
Damn.
Don't give up. Hobby is a great time waster...admittedly.
It's a great option for a keyboard with many mod-capabilities. I like the lists that are in this thread, and the one you've posted. New keyboard will come out eventually, the longer it takes the better it will be. A lot o advancements and the bar is being raised every few months. True-split is huge and that's the toughest sell it seems. But I picked up on that on Day 1.
Kinesis maybe should not have mentioned having an update in the works. Be more like Apple, it seems to work for them.
I checked out Apple watch yesterday. Very neat, very high quality. But I doubt it's for me, not a watch kinda guy and I don't need an update on my heartbeat
Offline vvp
« Reply #275 on: Sat, 02 May 2015, 12:40:41 »
Kayty keyboard.
But it is DIY (at least for now). That means if you do not enjoy building it then it is the most expensive keyboard ever ... or almost.
There are two more projects like Katy. Although, as far as I know, they are in earlier stages than Katy:
https://geekhack.org/index.php?topic=71263.0
https://github.com/adereth/dactyl-cave/
« Reply #276 on: Sat, 02 May 2015, 13:21:35 »
AWESOME PROGRESS ON THOSE PROJECTS!
But as was mentioned earlier in this thread, an adjustable thumb cluster is crucial to ergonomics  I've briefly discussed with Kurplop and believe he's been tinkering with a Kinesis for that purpose.
Offline vvp
« Reply #277 on: Sat, 02 May 2015, 13:33:13 »
You are probably right. Thumb cluster was the main reason I started Katy. Otherwise I would just stick with Kinesis Advantage.
As far as I know, it is ideal for me as it is now :)
« Reply #278 on: Sat, 02 May 2015, 13:36:16 »
You have a great project. I don't know if I've commented on it previously, but I'm impressed.
Thanks for the efforts, many appreciate it!
Also, I may finally get involved funding, marketing, pulling together several large companies for these types of products, so maybe at some point we can touch base as you get further along.
Offline vvp
« Reply #279 on: Sat, 02 May 2015, 13:45:58 »
Thanks.
Offline natas206
« Reply #280 on: Wed, 06 May 2015, 12:27:22 »
I can say confidently the new version will not be available within 3-4 months. I am sorry it's taken so long. We had a number of setbacks that delayed progress and I really thought at the time we would have had a new version by now, but things happen.
Offline pnutster
« Reply #281 on: Wed, 06 May 2015, 12:31:47 »
Thanks for the reply.
Definitely went for the 25% off deal. And now have to ponder about the recent additional options... RED LF hmmmmm - too many choices!!!
Kinesis Advantage
Apple TrackPad
Offline user888
« Reply #282 on: Tue, 02 June 2015, 03:18:20 »
Thanks for the reply. Now I know I don't have to check your website daily :-) Any teasers about the new keyboard in the meantime?
Offline m0j0
« Reply #283 on: Fri, 12 June 2015, 16:58:06 »
Excellent news! I just have three questions, if you can answer them:
  • Will the new Advantage model have a fix for the USB 3.0 issues with Windows 7?
  • If so, will there be an upgrade path for existing Kinesis Advantage customers, such as swapping out the USB daughtercard? My keyboards are fairly recent models.
  • How can I sign up to become a beta tester?  ;D
I'm new to the board, and this is literally my first post. I stumbled across the site searching for a more elegant solution to the Windows 7 issue without having to use the PS2 adapter kludge. The kludge DOES work, but it bugs me on a fundamental OCD level. I have been very happy with my Advantage keyboards, with the exception of the Windows 7 USB 3.0 driver issue.
m0j0
Offline jamadagni
« Reply #284 on: Sun, 14 June 2015, 23:24:19 »
Maybe get rid of the non mechanical keys and add a trackpoint?
+1 for both of the above.
I guess lots of people dislike the non-mechanical F keys on the Advantage. It's like a blot on an otherwise well-thought out device, and basically the one big thing that's preventing me from going for an item right now. Especially when doing sequences like Ctrl+Alt+Fx it's going to be weird hitting a non-mechanical key just for that last keystroke.
Also, the big space in the middle of the two wells seems an ideal place for a touchpad (I never got the hang of trackpoints). You can move the LEDs (with a bit more separate please) to the top above the touchpad, and place the Kinesis/Advantage logos to the left and right of the thumb areas.
Edit: On second (or actually third!) thoughts, looking at other posts, it seems a trackball is possibly more useful than a touchpad (especially when navigating to distant areas of the screen)...
« Last Edit: Mon, 15 June 2015, 06:01:02 by jamadagni »
Offline jamadagni
« Reply #285 on: Sun, 14 June 2015, 23:42:30 »
It seems that that drop is over and right now 145 users are requesting a new one for a target of 200. Perhaps the new drop can target the new item? Is there any projected MRP cost for the new model and how much it will cost on a drop?
Thanks.
Offline m0j0
« Reply #286 on: Mon, 15 June 2015, 09:35:07 »
I like the idea of making the function keys mechanical, but I'm opposed to adding a touchpad or trackball to the Advantage. I think that between the keys is an awkward place to put a trackball or touchpad, and I prefer to keep my mouse to the side of the keyboard. Just my opinion, of course. Hopefully if Kinesis DID implement something like that, it would be easy to completely disable.
Offline davkol
  •  Post Editing Timeout
« Reply #287 on: Mon, 15 June 2015, 11:54:58 »
I'd be great, if the empty space wasn't stupidly curved, and I certainly wouldn't pay premium for a touchpad (or probably anything else for that matter, because I already have a decent trackball, which cost 1/2 of a Kinesis Advantage).
Offline goflo
« Reply #288 on: Fri, 19 June 2015, 10:15:14 »
After some weeks with a Slimblade Trackball between my ergodox I must say....I would prefer a seperate mouse. I keep hitting the thumb cluster with my palm. So turning the hand to the left for the trackball or right for the mouse....doesn't matter to me  :rolleyes:
But what matters....any ETA available? Any news for Kinesis?
Offline dusanx
« Reply #289 on: Fri, 19 June 2015, 16:37:54 »
Ok, I've been watching this thread for ages. Happily typing on my LF so I'd like to see new version and upgrade while we are young ;)
Only real answer to pointing device positioning is to split halves and I damn hope that's what Kinesis did. That way any device can fit on either side or in the middle, without forcing people to adopt whatever Kinesis may or may not be attaching to Advantage. Advantage is perfect for me but pointing device and its position are far too individual to have one size fit all adoption.
Less important, but I'd love to see some crazy Japanese red lacquer keys edition, like that rare HHKB has.
Offline Ghibli
« Reply #290 on: Tue, 23 June 2015, 01:28:45 »
hmmm
Offline incrediblemath
« Reply #291 on: Mon, 06 July 2015, 23:09:51 »
I currently have an Apple Magic Trackpad velcro'd to my Kinesis in-between the keywells, and I've ended up not using it that much. Without the ability to use the trackpad's hardware click, it's useful only for scrolling and the occasional pointing with tap-to-click. I'd much prefer a trackpoint in the same area, if only because I dislike having to do multiple mouse-like gestures to select/drag items over long distances (and the latency added to support that).
Offline curious
« Reply #292 on: Wed, 15 July 2015, 20:37:59 »
Is this new version looking more like 2016?  Debating if I want to wait at all.
Offline dusanx
« Reply #293 on: Mon, 10 August 2015, 03:42:04 »
"I am here... on your desk!"
Cmon guys, some new info?
Offline vvp
« Reply #294 on: Mon, 10 August 2015, 06:55:15 »
No, you do not want to wait. Almost nothing is on time. I would say the only difference is when a company announces something which is already made and stocked. But in such a case the expected release is always at most a month or two in the future. So if something is announced in a longer time frame then consider it vaporware.
Buy the best you can afford now and replace it when something new and better is released.
Offline Snarfangel
« Reply #295 on: Wed, 19 August 2015, 09:13:48 »
I'm not sure if natas206 is still keeping an eye on this thread (probably so, but one never can tell), but on the software side of the keyboard, can you make reprogramming the keys as easy as the keyboard layout analyzer on the patorjk.com website (http://patorjk.com/keyboard-layout-analyzer/#/config)? You can drag and drop keys from one place to another, or click on a key and change the character associated with it. Plus, you can put separate layers on each key from the same interface (Primary Key, Shift Key, Alt Gr, Shift + Alt Gr) and have everything clearly visible on the main screen.
A keyboard that allowed changing layouts that easily, and exporting/importing layouts from one keyboard to another (which would allow easy sharing of layouts) would be awesome.
(The software may already be set in stone, or perhaps a variation of the Ergodox configurator is being used, or something else entirely, I just thought I would ask).
Offline user888
« Reply #296 on: Thu, 20 August 2015, 03:22:31 »
A teaser would be welcome to prevent me from buying an ErgoDox when it appears again on Massdrop again...  :D
Offline natas206
« Reply #297 on: Fri, 21 August 2015, 15:36:01 »
Thanks for your patience everyone, we are really close!
Just so you know what to expect, the overall design of the keyboard is going to be pretty much the same. What will be changed is all of the electronics. As some of you know, our current Advantage keyboard have experienced some compatibility issues (mainly the Windows 7 USB 3.0 problem). Our main focus has been redesigning the electronics from the ground up to resolve all of these issues and eliminate some of the old bugs (stuck modifier for example, as well as add some really cool new features. There were a few delays on the way but we are very close now.
Offline Snarfangel
« Reply #298 on: Fri, 21 August 2015, 18:27:36 »
I really look forward to seeing pictures of it, then seeing reviews, then seeing it show up on Massdrop.  :))
Offline dusanx
« Reply #299 on: Sat, 22 August 2015, 09:40:13 »
Noooo. Split it in half. Make two halves. You know you want to. Its not too late! Do it! Do it! USB compatibility while probably important for some does not change much for many others. It is forced compatibility 1.x upgrade, not 2.0 jump I was hoping for.
