Author Topic: Quick Question about PBC and Plate  (Read 3015 times)
Offline TheQsanity
  • SmallFry Lovin'
« on: Fri, 05 October 2012, 16:39:38 »
Is there any way to use a PBC switch type for a plate board or a Plate switch on a PBC board?
If there is a way would it be cost efficient at all?(for example using an old board from ebay for switch parts)
SmallFry! <3
Re: Quick Question about PBC and Plate
« Reply #1 on: Fri, 05 October 2012, 16:45:26 »
Yeah it's fine, PCB mounted switches just have these two pegs on top to fit onto the PCB. All you'd have to do to fit them on a plate mounted board is break them off. I don't know if it works the other way around, I'm not sure how sturdy it would be to just have them soldered.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 05 October 2012, 17:07:03 »
You don't want to use plate switch on pcb mount. It won't be sturdy enough without the pins to keep them in place. If you want to change switch type on pcb mount with plate switch, it would be best to leave the original switch soldered, and simply open the tops and switch the stem and/or springs.
Some plate mount boards actually use pcb mount switches too, so it just depends on the board in question if you would even need to remove the pins or not.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #3 on: Fri, 05 October 2012, 17:13:05 »
I'm sure lysol is right, but doesn't the plate switches still have that plastic circle lead on the bottom?  I always figured those two side plastic pieces were more for the alignment than stability.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #4 on: Fri, 05 October 2012, 17:19:37 »
Have any of you guys done the leaving the bottom of the switch soldered and just switching out the top?(does I hinder with feel or durability?)
Or is it recommended.
Is there a place to buy the pins(Home improvement store, online or something)
Or is it not possible to add the pin onto the switch?
SmallFry! <3
« Reply #5 on: Fri, 05 October 2012, 18:06:21 »
It's not possible to add the pins onto the switch really unless you've got a lot of time and super glue... they're attached to the plastic piece on the bottom of the housing.
Hopefully this can help you get a better understanding:
From Left to Right, Plate mount, PCB mount, PCB mount with snapped off pins
individual shots in the same order:
http://i.imgur.com/eRcAg.jpg
http://i.imgur.com/rBkij.jpg
http://i.imgur.com/5AsJ3.jpg
« Last Edit: Fri, 05 October 2012, 18:16:44 by Sifo »
Offline TheQsanity
  • SmallFry Lovin'
« Reply #6 on: Fri, 05 October 2012, 18:22:57 »
Ah, I see. Some arts and crafts pro may be able to get it down! Lol jk
And Which way is more recommended to switch out the switch? By soldering it or popping the cap off? Or are they the same?(just want to get an idea of what the majority of you do)
edit: Thanks for the pics btw much appreciated!
« Last Edit: Fri, 05 October 2012, 18:25:40 by TheQsanity »
SmallFry! <3
« Reply #7 on: Fri, 05 October 2012, 18:24:18 »
For most plate mounted you HAVE to desolder it to take the switch off. On certain platemounted boards like the Phantom and LZ*, you can just take the top part of the housing off. For PCB mounted ones, you can just pop the switch off without desoldering.
« Last Edit: Fri, 05 October 2012, 18:49:23 by Sifo »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #8 on: Fri, 05 October 2012, 18:34:59 »
On certain platemounted boards like the KMAC, you can just take the top part of the housing off
Not true of the KMAC.  The Phantom is the first known example of a plate board that allows opening switches while still mounted.  There is also a newer design from LZ using the same concept but executed differently.
If it's possible to take the top half of the housing off that is the preferred method.  Mostly it just boils down to what's easy.  Besides, de-soldering has a higher risk of damaging the PCB or switch.
Filco w/ Imsto thick PBT
« Reply #9 on: Fri, 05 October 2012, 18:48:46 »
My bad, it was one of the Korean keyboards :P
Offline TheQsanity
  • SmallFry Lovin'
« Reply #10 on: Fri, 05 October 2012, 18:52:39 »
Thanks sounds good, probably what I would do.
I would assume that some of you would rather de-solderer for whatever reason, not sure how many if there are any.
SmallFry! <3
« Reply #11 on: Fri, 05 October 2012, 18:54:15 »
Well, it's because with most platemounted boards you have to desolder :( I wouldn't if I had a Phantom plate.
