Author Topic: Cherry Mx PCB Mounted Switch [Limited Stocks]  (Read 44722 times)
Offline ernestrome
Re: Cherry Mx PCB Mounted Switch [Limited Stocks]
« Reply #50 on: Fri, 16 November 2012, 20:45:53 »
The subject says PCB mount, the part numbers are PCB mount, the third sentence of his post says PCB mount... I'm pretty sure that should get the point across.
Are you sure? How about a picture?
Cherry G80-3000 HEMGB - British Layout, Clear Keyswitches, Doubleshot keys
IBM Scrollpoint 3 mouse trackpoint style scroll device
Offline ernestrome
« Reply #51 on: Tue, 27 November 2012, 09:05:00 »
I am having trouble getting a response from Marc since sending my payment.
edit i have heard from marc now.
« Last Edit: Tue, 27 November 2012, 18:32:17 by ernestrome »
Offline Caaaarrrt
« Reply #52 on: Tue, 27 November 2012, 15:41:22 »
It's been a month since mine were sent and I still haven't received them, I hope they aren't lost. Silly customs probably have them or something, hopefully they will show up soon though.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
Offline Sai
« Reply #53 on: Wed, 12 December 2012, 03:04:03 »
i'll probably buy brown switches by next week.
Offline TheGrey
« Reply #54 on: Wed, 12 December 2012, 08:15:42 »
clears all sold out...what a suprise :D
Offline Marclgw
« Reply #55 on: Sat, 15 December 2012, 09:38:48 »
Other than clears, others are still available, all pm-s replied.
Offline rek55
« Reply #56 on: Wed, 02 January 2013, 21:21:06 »
Are you accepting small orders as well? If so, I'd love to get:
- 10 Reds
- 3 Blues
Also, if you know the answer, will these work in a Das keyboard? I know Das is plate, not pcb, but from what I've read I can just cut off the plastic legs and then it should fit.
« Last Edit: Thu, 03 January 2013, 00:08:06 by rek55 »
My future Das Ultimate S, all modded up. For now, it's a bit more black.
Offline Gupgup
« Reply #57 on: Wed, 02 January 2013, 22:08:13 »
Just to be clear, these switches will go easily into my Poker, correct? If so I will take 70 blues if there is some left! Let me know!
« Reply #58 on: Thu, 03 January 2013, 01:18:11 »
- 10 Reds
- 3 Blues
You'll have to trim the legs to get them to fit in your (plate mounted) DAS (If it's a Gen3 or later, the DAS II is a PCB-mounted cherry). Desoldering and removing the switches is a little harder for plate mount, as you need to desolder the switch, then compress the top and bottom to remove it. It took me a few tries, but I got it pretty quick.
I don't know about this GB, but the poker uses PCB-mounted keyswitches. To swap them out fully, you'd have to desolder them, but an easier way is to just open the switches and change the stems/springs
Offline WhiteFireDragon
    • youtube
« Reply #59 on: Thu, 03 January 2013, 02:36:33 »
Marclgw, where are you getting these switches from? Any chance you'll get more clear ones?
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #60 on: Thu, 03 January 2013, 23:35:43 »
^ there are a few questions ahead of me but....
if you are still accepting orders i would like to order 70 brown pcb switches
Offline Marclgw
« Reply #61 on: Fri, 04 January 2013, 09:37:37 »
- 10 Reds
- 3 Blues
The stems and springs are the same but if you were to de solder the default switches and fit them in it will not, as PCB Mounted switches have an extra (leg) pin that the PCB do not have a placement for it.
Hi WFD,
   I am sorry to say that i am unable to get any more clears as Cherry themselves have that tons of orders which leads current orders of switches to be ready only in 1st quarter next year, 2014.
Let me know how many you need, i see if i can get some.
Cheers
PM me =D
Orders are always open =D.
Pm me if you are keen.
Cheers.
Offline Glod
    • YouTube Channel
« Reply #62 on: Fri, 04 January 2013, 12:24:38 »
You have a PM :)
Offline Marclgw
« Reply #63 on: Fri, 04 January 2013, 12:34:57 »
All pms replied
Offline Kalmarauder
« Reply #64 on: Sun, 20 January 2013, 18:50:23 »
I sent you a pm. I'd like to buy 250 reds.
Offline Gupgup
« Reply #65 on: Sun, 20 January 2013, 22:34:31 »
I'll take 150 reds please!
Offline Sai
« Reply #66 on: Mon, 21 January 2013, 23:29:12 »
is there any red switches left? need to fix one of the switches on my poker. :D
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #67 on: Tue, 22 January 2013, 01:58:46 »
Hi,
Are there any switches left? I have some broken boards & creating few more. love to add some switches.
Need 150 red and 150 clears.  If no clears, then can manage with browns.
Sent you PM as well.
« Last Edit: Tue, 22 January 2013, 02:03:38 by blueSmoke »
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline Marclgw
« Reply #68 on: Thu, 24 January 2013, 16:42:26 »
Is there any pms that I have yet to reply?
Current quantity available,
80 red switches
30 clear switches
250 blue switches
200 brown switches
Offline Gupgup
« Reply #69 on: Sat, 26 January 2013, 19:01:33 »
I would be interested in 150 blues! Will PM you also
Offline philpirj
« Reply #70 on: Mon, 28 January 2013, 13:32:55 »
Mine blues has arrived!
Thanks, Marc!
Offline Tensor
« Reply #71 on: Fri, 08 February 2013, 05:04:45 »
Hopefully you still have some browns  :D
PM sent.
Offline calavera
« Reply #72 on: Wed, 27 February 2013, 01:53:38 »
Any more clears/whites coming in stock? I need about 100
Offline badcop
  • thorpe thocking master race
« Reply #73 on: Fri, 01 March 2013, 10:39:52 »
YGPM
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #74 on: Sun, 03 March 2013, 14:32:36 »
Can you update the OP? It was last updated in October....
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline Marclgw
« Reply #75 on: Tue, 05 March 2013, 07:52:15 »
All red and clear switches are out of stocks.
Offline Soulpyre
« Reply #76 on: Mon, 11 March 2013, 12:23:34 »
You've got a PM Marclgw
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline akm
« Reply #77 on: Tue, 07 May 2013, 00:47:51 »
Hi Marclgw!
I would like to order  150 pcs MX1A-E1JW  [ Blue ], If you can ship it to Russia.
Offline Darhuuk
« Reply #78 on: Sat, 06 July 2013, 13:00:47 »
I'd like to order 32 reds (MX1A-L1DW) and 8 browns (MX1A-G1JW), if this is still possible (not quite sure after reading this thread). Shipping would be to Belgium. Could you PM me about this, please?
« Last Edit: Sat, 06 July 2013, 14:49:57 by Darhuuk »
Offline Marclgw
« Reply #79 on: Sun, 07 July 2013, 23:10:11 »
All switches sales have stopped for now, will pm those who are keen if i have the qty.
Sorry about it.
Offline Darhuuk
« Reply #80 on: Mon, 08 July 2013, 02:26:03 »
Do you have any idea when you might receive new switches (i.e. in 2 weeks, in 2 months, in ...)?
Offline Darhuuk
« Reply #81 on: Mon, 08 July 2013, 02:26:45 »
Edit Sorry, seems like I double-posted.
Offline Vitaly
« Reply #82 on: Sat, 19 July 2014, 09:29:31 »
Do you see those little brown/orange bars on the bottom of each switch? Those are called diodes.
What are diodes used in switches? I can't find switches with diodes and want install them on pcb, what diodes should I use?
Offline Neal
  • Skype: iNewbcake
« Reply #83 on: Sat, 19 July 2014, 09:43:38 »
http://www.digikey.com/product-detail/en/1N4148/1N4148FS-ND/458603
or
http://www.gonskeyboardworks.com/others/13-diodesdip-20-pcs.html
or if you want SMD
http://www.gonskeyboardworks.com/others/88-diodessmd-100pcs.html
Offline Vitaly
« Reply #84 on: Sat, 19 July 2014, 17:39:50 »
or
or if you want SMD
Thanks, bought smd version
