Author Topic: Hello!  (Read 3843 times)
Offline mironccr345
Hello!
« on: Tue, 09 October 2012, 20:26:28 »
Hi everyone! Just wanted to introduce myself. Also, does anyone know where I can get key caps for a Dell AT101W? I cleaned the keys and lost the "f" key.  :-[
Hope someone can help? Thanks again and I'm glad to be apart of the Forum.
Re: Hello!
« Reply #1 on: Tue, 09 October 2012, 21:38:54 »
Welcome to Geekhack!
Not sure about the replacement key caps, other than searching eBay or Classifieds for a donor, but that is a nice keyboard.  Custom case?  Or custom paint job??
Re: Hello!
« Reply #2 on: Tue, 09 October 2012, 21:39:26 »
That's a sick case! Good luck finding a replacement F key, and welcome to Geekhack.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Offline mironccr345
Re: Hello!
« Reply #4 on: Tue, 09 October 2012, 21:50:04 »
Thanks for the reply and greetings.
The case is wrapped in 3M Carbon Fiber Di-Noc. Not as easy as I thought it would be, but the end result was worth it. I'm currently using the "pagedown" key as a replacement.
Keys look better with better lighting.
Thanks for the links. I might have to buy one for spare parts? But the search continues.  :D
Offline absyrd
  • CPT HYPE PADAWAN
Re: Hello!
« Reply #5 on: Wed, 10 October 2012, 11:25:01 »
I posted in your other thread. If you are just looking for 101 spare caps, your best bet for the cheapest replacement keys is going to be a thrift store or local e-cycling place. I've seen many for $1-$3. You can also find other ALPS compatible keycaps from other brands.
Offline 4LI4Z
Re: Hello!
« Reply #6 on: Wed, 10 October 2012, 12:20:25 »
Welcome to geekhack and good luck finding your keycaps!
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline tillertow
Re: Hello!
« Reply #7 on: Thu, 11 October 2012, 07:25:33 »
Love the carbon case :)
FS: 6Gv2 Key caps ISO/scandinavian:
http://geekhack.org/index.php?topic=36427.0
Offline Internetlad
Re: Hello!
« Reply #8 on: Thu, 11 October 2012, 16:59:58 »
asdpagedown
On topic:
Wouldn't the F from a broken Focus FK-2001 work as well? Or pretty much any similarly coloured ALPS board?
I'd say keep an eye out. Somebody is bound to be selling and hit up thrift stores. I love that, never know WHAT you'll find for cheap.
« Last Edit: Thu, 11 October 2012, 17:02:17 by Internetlad »
"Beep . . . Beep . . . Beep" -Sputnik I
