Author Topic: [IC] RGBYO double shot kit [need color help]  (Read 55221 times)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] RGBYO double shot kit [need color help]
« Reply #100 on: Fri, 16 November 2012, 19:47:57 »
Uhm, shift is green, control is red, alt is blue.  Don't question the wisdom of Cherry  :mad:
Well there are 4+ RGB kits already available (MBC, hashbaz, aggiejy, a korean one). Also sometime soon Sherryton is going to have one available as well making 5+. So since we have around 100 extra cherry escapes from the cherry red set in black and white legends I'm going to bundle with these sets, I thought it would be cool to keep the normal color scheme, and just do a simple rotation of the colors. That way people will have a blue and red escape instead of two escape keys. Variety is the spice of life son, the more I look at it, the more it grows on me.
Offline gameaholic
« Reply #101 on: Fri, 16 November 2012, 20:35:42 »
Now that someone sold me a hashbaz RGBY (it's in the mail) I'm more open to the alternative color rotation.  Maybe have each key available in all three colors?  Someone could get all red, all blue or all green modifiers.
« Last Edit: Fri, 16 November 2012, 20:38:18 by gameaholic »
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline mickd
« Reply #102 on: Sat, 17 November 2012, 04:19:33 »
I'm putting my interest towards seeing completely new colours instead of just rotating it. Maybe using the secondary colours?
Offline netdevil
« Reply #103 on: Thu, 22 November 2012, 08:21:50 »
Ok definitely interested when this goes up  ;D
Offline Mangeun Ethan Jang
  • Location: Molundae LotteCastle Apt. 106-1003, Dadae1-dong, Saha-Gu, Busan, South Korea
« Reply #104 on: Fri, 23 November 2012, 12:58:46 »
I interested with 1.5 kit : ) Cheer up! :-* :p :eek: :cool:
Offline BimboBB
« Reply #105 on: Fri, 23 November 2012, 13:45:02 »
Interested as well!  :)
Offline Sai
« Reply #106 on: Mon, 03 December 2012, 19:27:11 »
i am interested as well.
Offline phetto
  • HHKB JP
« Reply #107 on: Wed, 12 December 2012, 05:14:26 »
Can you guys just pick a set and go.
Offline bazemk1979
« Reply #108 on: Thu, 03 January 2013, 20:32:51 »
interested in the ansi set with white legends
Offline bazemk1979
« Reply #109 on: Thu, 03 January 2013, 20:36:57 »
So is it descided with black legends or white legends? I presume these are DS from SP?
Offline redeye
« Reply #110 on: Sat, 05 January 2013, 12:50:58 »
I'm also interested in this  :D
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #111 on: Sat, 05 January 2013, 13:31:59 »
1.5
lock and load ;D
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Sephiroth
« Reply #112 on: Wed, 09 January 2013, 04:32:32 »
1.25 Set
2x1.25 ctrl
2x1.25 alt
2x1.25 Window
1x1.25 menu
1x2.75 right shift
1x2.25 left shift
esc 1x
i like it!!
