Author Topic: Best SSK or SFF Vintage Keyboard?  (Read 1242 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Tue, 16 October 2012, 12:03:42 »
I recently did a USB conversion on a Leading Edge DC-2014 (With so much help from Soarer, thanks!) and then proceeded to give it to a family friend whom worked at LE back in the 80's. I had fun with that project so I would like to find a nice, relatively decent priced (no more than 60) keyboard to convert. Preferably ALPS as I liked the feel of the blue alps but any mechanical switch would do. Thanks in advance guys, I know someone will know what to get.
EDIT: I have too many full sized keyboards so that's why I want an SSK/SFF.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Re: Best SSK or SFF Vintage Keyboard?
« Reply #1 on: Wed, 17 October 2012, 09:20:38 »
There's that Ortek MCK-84 that always looked good, the keypot/vivanco is pretty small and similar to it.
And ofcourse the siig minitouch.
Your best bet might be to get a broken fullsize ALPS and replace the keyswitches, as many of these aren't that great. I'm a little biased against ALPS, so I can't say.
