Author Topic: Windows 8, your thoughts?  (Read 65190 times)
Re: Windows 8, your thoughts?
« Reply #300 on: Wed, 23 January 2013, 08:33:25 »
Wait, this is downloading, right?
I would love to have an actual disk, or be able to burn one myself.
My DSL connection is pretty lame, but are we talking about downloading at least a couple of gigs, then installing?
I was planning to try this next week.
- D Trump 2026-10-24
Offline TheProfosist
  • Custom Layouts Only!
« Reply #301 on: Wed, 23 January 2013, 08:53:58 »
yea you download it
you have the option to burn a disc or make a flash drive or if you get the ISO you can do both
yea a single layer DVD
go for it do it before the 31st though
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #302 on: Wed, 23 January 2013, 08:55:15 »
I installed windows 8 and it took about 1hr to completely install.
1 hour!? I think it's the fastest version of Windows to install. Was it an upgrade install? Maybe you need a new computer??  :)
It took about 30mins to download the file, and another 45min + to upgrade from windows 7.. my computer is quite cheap actually. In USD it costs like 500 usd to build? No SSD as well :P
Offline mmmty
  • bang! bang!
« Reply #303 on: Wed, 23 January 2013, 09:24:41 »
OIC, it was an upgrade that's why it took so long.
Keyboardless
Offline daerid
    • Rossipedia
« Reply #304 on: Wed, 23 January 2013, 11:29:34 »
I was blown away by how fast Windows 7 installs. Windows 8 blows Windows 7 out of the water.
I used the Windows 7 USB/DVD Download Tool to make an installable USB drive (min 4GB required). Using that, a fresh Windows 8 install took about 10 minutes.
« Reply #305 on: Wed, 23 January 2013, 11:33:47 »
i have yet to try over USB 3.0 but i kind of want to try :D
Offline mmmty
  • bang! bang!
« Reply #306 on: Wed, 23 January 2013, 11:43:02 »
USB 3.0 install to SSD drive =  :eek:
Keyboardless
« Reply #307 on: Wed, 23 January 2013, 12:45:14 »
yep ill try when i put win8 on my desktop
Offline dohboi
« Reply #308 on: Wed, 23 January 2013, 14:52:02 »
Haven't tried that yet, only used the OEM disks so far. I wonder if its any faster on striped SSDs. :p
Offline mmmty
  • bang! bang!
« Reply #309 on: Wed, 23 January 2013, 15:03:42 »
One problem I see is WinPE may not have USB 3.0 driver and only reading at 2.0 speed or not seeing USB drive at all.
Keyboardless
« Reply #310 on: Wed, 23 January 2013, 15:08:36 »
Interesting variation in install time, which could depend on the hardware it was installed on and the installation media.
I had Windows 95 install down to about 8 minutes back in the day - going from a new blank HDD to a fully working Windows 95 on the network with internet access.
Offline daerid
    • Rossipedia
« Reply #311 on: Wed, 23 January 2013, 15:30:27 »
How the hell did you do that? Slipstreamed install?
I've never seen Win95/98 take less than 70 minutes from the install CD.
Re: Re: Windows 8, your thoughts?
« Reply #312 on: Wed, 23 January 2013, 19:13:51 »
win7 had this problem but with the built in usb 3.0 win8 driver thi should be all good.
« Reply #313 on: Wed, 23 January 2013, 19:39:25 »
This was maybe 10 years ago, I really can't remember now, apart from the time.  There wasn't much of it to copy, not like the dozens of GB of bare OS install that you get these days.
Offline darksakul
  • If it is not broken fix it until it is.
« Reply #314 on: Wed, 23 January 2013, 22:33:03 »
    Will you be getting a copy?
Maybe, just for test/ Educational purposes
    What do you think of the low price?
Not bad BUT this should be the norm not the exception. The Price goes back up after April.
    What are your opinions on the new features?
Why would I want a Table UI on a Desktop PC?
Touch Screen Gestures do not mix with mouse and keyboard controls.
    Will this new OS be a problem for PC users?
Yes. New UI  is not very intuitive UI for anyone not using a touch screen.
I also had some admins that worked with NASA and the FAA tell me this OS is crap.
    What do you think of the new ribbon feature in place of the Windows Explorer address bar?
WTF?! Don't fix what is not broken MS!
    Any features that you love and is the soul reason you are getting the new OS?
What are you smoking, and can I have some?
    Will you be getting a Windows 8 tablet or Smartphone?
Unlikely. Android is my baby.
    How will the new OS affect your gaming?
Not at all as I am sticking to Win 7
    Anything else that you think that should be addressed about Windows 8?
Microsoft stop shoe-honing **** no one wants. Also the Menu UI visual theme is ugly as sin.
You must defeat Sheng Long to stand a chance.
Offline daerid
    • Rossipedia
« Reply #315 on: Thu, 24 January 2013, 01:06:29 »
True story. I haven't done it on modern hardware.
« Reply #316 on: Thu, 24 January 2013, 23:44:12 »
I've been having some problems lately. yesterday there were 25 updates to be installed on my computer. i believe it's the update of the windows 8 drivers.. after it reaches 100% configuration, it just shows "Restarting" ( I clicked update and restart ). The restart continued for quite a while, until i had to manually switch off.
Offline Turkishrambo
« Reply #317 on: Fri, 25 January 2013, 09:09:03 »
The messaging app is SO silly, they stop supporting MSN but the implement msn messenger INTO the OS?
-.- so weird.
Ive been using it for about a week now and it still feels like one of the notorious bridging OS's microsoft seems to like doing. If you install classic start menu then yeah youll likely be happy, theres also small features i like... however there is ALOT of rough edges that NEED fixing, which is comparable to vista/7.
The messaging app broke my skype until i stopped using my microsoft account and used a local account instead.
The only reason to get it right now is the price, which is why i got it.
« Reply #318 on: Fri, 25 January 2013, 13:21:31 »
-.- so weird.
MSN/Windoows Live Messenger is now dead they integrated it with skype
« Reply #319 on: Fri, 25 January 2013, 13:21:50 »
never use driver from windows update unless you have to
Offline sordna
« Reply #320 on: Fri, 25 January 2013, 13:28:35 »
Anybody knows when a web-version of skype will be available ?  Messenger worked as a web app (and most of Office does) ...
« Reply #321 on: Fri, 25 January 2013, 13:57:07 »
I havnt the slighest clue though idk how likey itll be available since everything runs on apps now days.
« Reply #322 on: Fri, 25 January 2013, 13:58:16 »
O wait sorry a bit tired here would you be talking like a "cloud" app?
Offline sordna
« Reply #323 on: Fri, 25 January 2013, 14:36:27 »
Yes, actually Microsoft is converting everything to cloud apps, no? Even for enterprise (office365) but also if you have hotmail / outlook.com account, you can create and edit office documents using a web browser, even with a chromebook. So everything is moving to the cloud, and I would guess Skype (now a Microsoft product) would be too, especially if it replaces Messenger which had a web-app version.  Look at it another way, all IM / video chat apps (yahoo, google talk, microsoft messenger) were web based, and now Microsoft will be the only one that will not have a web-based option?  No, Skype is bound to have a web-app version, so you can use it on thin clients, chromebooks, and the like, my question is not "if" but "when" ? :-)
« Reply #324 on: Sat, 26 January 2013, 10:41:00 »
yea i agree that everythings goinkg to web apps which I dont like but its whats going to happen
Offline WRXChris
« Reply #325 on: Sat, 26 January 2013, 11:47:13 »
After a few days using win8 + classic shell, im very happy I grabbed it for $15 while I could!  I may pick up another license for my old crappy atom-powered netbook; does anyone know if it runs faster than 7 on very low-end machines?
I really like the small touches like better info when copying files, smoother driver installs, etc. I havent had flickering issues with eyefinity like I did with 7, but they could show up later, they usually started when updating amd graphics drivers without using driver sweeper first.  The start screen is an atrocity but thankfully there are quite a few third party start menu apps, im using classic shell because its free.  Overall I like it quite a bit so far, I havent found anything that's worse than 7 IMO!
« Reply #326 on: Sat, 26 January 2013, 11:50:16 »
great to hear ive had a close experience
Offline TheQsanity
  • SmallFry Lovin'
« Reply #327 on: Sun, 27 January 2013, 20:43:18 »
We still have three more days to redeem the $15 Windows8 right?
http://www.windowsupgradeoffer.com/en-US/SelectCulture?previousController=Registration&previousAction=Index
I already have one but for $15 dollars, I might as well pick up another.
SmallFry! <3
« Reply #328 on: Mon, 28 January 2013, 15:58:48 »
It clearly says you have to buy a new windows 7 computer to be qualified
"Buy a qualified Windows 7 PC today
Register for the offer
Redeem your upgrade"
