Author Topic: CM Storm Power-RX Hybrid Mouse Pad  (Read 7062 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Thu, 08 November 2012, 23:13:42 »
http://www.cmstorm.com/en/products/surfaces/Power-RX/
Just saw this now, it says cloth + rubber coating.  Wouldn't that be super grippy and slow?  :confused:
Anyone have any experience with this?
Offline vun
  • Just one more thing
Re: CM Storm Power-RX Hybrid Mouse Pad
« Reply #1 on: Fri, 09 November 2012, 06:29:21 »
Could be something similar to the old SS 5L, if it is I'm getting this as soon as I can.
« Reply #2 on: Fri, 09 November 2012, 11:59:36 »
The rubber coating is on the bottom for non-slip on your desk.
Offline vun
« Reply #3 on: Fri, 09 November 2012, 12:40:01 »
"A low friction textured weave submerged into a thin layer of a special rubber compound that sits on a soft anti-slip silicon base that perfectly grips onto any surface. "
The surface seems to be a texture-rubber hybrid with a silicon bottom that keeps it from slipping.
Offline swagpiratex
« Reply #4 on: Fri, 09 November 2012, 12:45:46 »
Carter described this to me as a material that feels like a wetsuit.
Offline Hyde
« Reply #5 on: Fri, 09 November 2012, 15:08:51 »
Yupe someone else went to the site like I did good job  :P
That sounds very slow to me, why would anyone want that =____=
Offline swagpiratex
« Reply #6 on: Fri, 09 November 2012, 15:23:35 »
lol, I'll check it out tonight and try to take pics / post impressions.
Offline swagpiratex
« Reply #7 on: Sat, 10 November 2012, 00:47:02 »
So took a look at the Power today, and it's harder than the Speed, which feels like a thicker version of the QCK+ that I have. The power has a sort of manta ray/wet suit kind of feel. Didn't take pictures because the lighting wasn't adequate.
Offline Hyde
« Reply #8 on: Sat, 10 November 2012, 15:01:40 »
Mmmmm I wish I know how manta ray feel like LOL.  Though how fast would you say this compares to other common mousepads?  Say like compare to QCK, Goliathus, Puretrak Talent, or hard pads like Razer Scarab... etc?
Offline swagpiratex
« Reply #9 on: Mon, 12 November 2012, 14:51:25 »
My experience with mousepads are very limited, unfortunately. Its rougher than the QCK/Speed. If I had to elaborate a little more, I would have to say it's a soft pad, but the pliable surface with the texture of a harder mousepad like the Scarab.
Offline Henkers
    • Youtube
« Reply #10 on: Sun, 24 March 2013, 14:43:55 »
I've always used cheap $2 mouse pads, I just can't see an expensive mouse pad doing much :x
Offline vun
« Reply #11 on: Sun, 24 March 2013, 15:24:32 »
I have a few el-cheapo pads that I've gotten as promos and stuff over the years, they're not all that bad and it's not like they're painful to use, but the more expensive pads I have are just miles better and make using the computer far more pleasant. As for performance, that's a far more complicated discussion I won't even start right now.
Offline Hyde
« Reply #12 on: Sun, 24 March 2013, 23:34:13 »
Yeah I'm trying to find a perfect balance between quality vs money.  Like I think QCK is amazing for the price.  But since I can afford to pay a bit more so I'm trying to see what better options are out there.  I'd say Artisan pads seats quite high in terms of quality but at the same time they're quite pricey.  So I'm hoping to find a middle ground somewhere in between  :)
Offline vun
« Reply #13 on: Mon, 25 March 2013, 06:35:21 »
I've heard the PureTrak Talent is supposed to be in that sweet spot, but I haven't tried it for myself yet. Enjoying my I-2 too much.
Offline Hyde
« Reply #14 on: Mon, 25 March 2013, 21:07:48 »
lol I still have too many mouse pads at hand now, but otherwise I think that will be the next one I try  :D
