Author Topic: how to put leds in cm quickfire rapid coz the PCB got no holes  (Read 7624 times)
Offline luckynet
« on: Fri, 16 November 2012, 23:40:16 »
so i want to LED'ize my CM Quickfire rapid but after opening it, i cant find them hole to put in them LEDs on zee PCB. any ideas guys?
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline esoomenona
  • Gnillort?
Re: how to put leds in cm quickfire rapid coz the PCB got no holes
« Reply #1 on: Fri, 16 November 2012, 23:42:05 »
Get a string of LEDs and run them under there somewhere?
Offline luckynet
« Reply #2 on: Fri, 16 November 2012, 23:46:56 »
where do i then solder them??
IBM Model M SSK
Offline esoomenona
  • Gnillort?
« Reply #3 on: Fri, 16 November 2012, 23:54:09 »
You wouldn't solder them, unless you could wire them to get power from the USB.
Other than that, I believe the only way would be to drill holes into the PCB, then make traces to all of them. I don't think you'd want to do all of that, but if you do, I'd be interested in seeing that!
Offline luckynet
« Reply #4 on: Sat, 17 November 2012, 00:06:45 »
looks like christmas.. hahaha. i guess i'll just shove the led's into the switches them string them up and connect them to the usb. it'll be sooo messy... Le Sigh...
IBM Model M SSK
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #5 on: Sat, 17 November 2012, 00:14:09 »
Now you can guess why people ask others, "Do you really need a keyboard with christmas lights?" when mocking backlit keyboards.
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline luckynet
« Reply #6 on: Sat, 17 November 2012, 00:17:06 »
i like christmas lights, plus having it on my desk all year around... so much joyous win..  :P
IBM Model M SSK
Offline FoxWolf1
  • 154
« Reply #7 on: Sat, 17 November 2012, 00:33:54 »
Although there do exist non-backlit keyboards that are designed so that you can add LEDs-- Plum 96, for instance-- I'm pretty sure the QFR is not one of them.
You may be happier with the results if you just sell the QFR and buy something backlit than if you go to great lengths to try and force the QFR to become backlit.
Offline luckynet
« Reply #8 on: Sat, 17 November 2012, 00:40:18 »
the plum is already on it's way from china since like 3 days ago. i saw some people modding theirs QFRs' and i tot why not mod mine as well... the desoldering is gonna be such a hassle T.T
IBM Model M SSK
Offline WhiteFireDragon
    • youtube
« Reply #9 on: Sat, 17 November 2012, 00:59:58 »
there's plenty of mods you can do to a CM quickfire, but adding LED backlit for all the keys is not one of them. There are no traces in the PCB to support the LEDs.
Offline luckynet
« Reply #10 on: Sat, 17 November 2012, 01:32:57 »
got link for them mods :)
IBM Model M SSK
