Author Topic: G80 vs a Filco for gaming  (Read 3512 times)
Offline Cafiend
« on: Sat, 17 November 2012, 13:19:32 »
Do any of you G80 owners prefer it for gaming over like a regular mech kb?  (BF3,SC2 ect)
Some of the models seem well sized for larger hands. And they look really niiice.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: G80 vs a Filco for gaming
« Reply #1 on: Sat, 17 November 2012, 13:23:29 »
I love G80, but only a few USB models that are currently available have better than 2KRO. Less than 6KRO can suck for certain types of gaming. Otherwise, you will want to buy a vintage AT or ps/2 model that has NKRO.
« Last Edit: Sat, 17 November 2012, 14:12:53 by lysol »
Offline phx
« Reply #2 on: Sat, 17 November 2012, 13:25:42 »
there are models with larger key caps? I thought they are all more or less the same.
Offline SmallFry
« Reply #3 on: Sat, 17 November 2012, 14:11:18 »
They would all be the same since the switch is the same. The G80 is a fine board though. :)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #4 on: Sat, 17 November 2012, 17:00:10 »
Two key rollover is not good on my opinion.
Other than that. Not much different.
SmallFry! <3
Offline blighty
« Reply #5 on: Sat, 17 November 2012, 18:45:14 »
My G80-18251865 has NKRO (6KRO over usb).  It is the Cherry version of the Raptor board (that was made by Cherry).  I have brown stems with black spri ngs  in it.  It works great for  me for FPS gaming as well as typing.  I go back and forth between my Filco mx black tkl and G80-1825 for my daily drivers with no complaints.
« Last Edit: Mon, 19 November 2012, 20:32:43 by blighty »
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline SmallFry
« Reply #6 on: Sat, 17 November 2012, 18:49:29 »
Aren't G80's PCB mounted?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Sat, 17 November 2012, 18:51:51 »
Almost all Cherry boards are PCB mount. There are very few that are plate mount
Offline SmallFry
« Reply #8 on: Sat, 17 November 2012, 18:59:58 »
That's what I thought... My 1800 is PCB I think.
Offline blighty
« Reply #9 on: Sat, 17 November 2012, 19:16:23 »
Don't you have an 1800?  My 182565 is the same layout, but with diodes,  1unit modifiers, and win/menu keys.  PCB flex is only an issue when you apply way more force than you would need to type/game.
« Last Edit: Mon, 19 November 2012, 20:33:07 by blighty »
Offline SmallFry
« Reply #10 on: Sat, 17 November 2012, 19:20:46 »
I don't have his cap puller handy, so I didn't pull a cap.
Offline inlikeflynn
  • file not found
« Reply #11 on: Sat, 17 November 2012, 19:24:11 »
My G80-1825 has NKRO (6KRO over usb).  It is the Cherry version of the Raptor board (that was made by Cherry).  I have brown stems with black spri ngs  in it.  It works great for  me for FPS gaming as well as typing.  I go back and forth between my Filco mx black tkl and G80-1825 for my daily drivers with no complaints.
don't you mean 1865 ?
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline SmallFry
« Reply #12 on: Sat, 17 November 2012, 19:28:59 »
Ah, inlikeflynn. Are 1800's PCB mounted?
Offline blighty
« Reply #13 on: Sat, 17 November 2012, 19:34:14 »
Ha, yeah 1865,  Damn touchscreen
EDIT: Ha, 1865 is correct.  Touchscreen fail
« Last Edit: Sat, 17 November 2012, 19:37:57 by blighty »
Offline inlikeflynn
  • file not found
« Reply #14 on: Sat, 17 November 2012, 19:35:29 »
Yes the 1800's are all PCB mount from cherry
You should be able todo the G81-1800 plate trick on them like on 3000's. But I haven't found one which fits yet
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline SmallFry
« Reply #15 on: Sat, 17 November 2012, 20:04:30 »
Thanks! What is this plate trick you speak of?
Offline inlikeflynn
  • file not found
« Reply #16 on: Sat, 17 November 2012, 23:39:51 »
the fake plate one sixty did long ago with 3000's: http://geekhack.org/index.php?topic=13165.0
but I wouldn't bother with that as something better might be in the works...
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline exousia7
« Reply #17 on: Sun, 18 November 2012, 19:13:32 »
Got a G80-3000 and I game with this all the time =D
