Author Topic: Unicomp, Matias destroyed my Realforce :-(  (Read 1709 times)
Offline blakespot
    • My (modest) keyboard gallery
« on: Sun, 18 November 2012, 17:21:13 »
A year ago I bought and loved a Realforce 87U with Topre switches. Then, a few months ago, I setup a standing station around my Mac Book Air and borrowed a friend's Matias Quiet Pro and used it, switching in and out with my Unicomp -- and using those other boards (neither of which I find perfect) makes me type horribly on my Realforce. The tops of the Realforce caps must be smaller than the others. It's so bad I had to take the Realforce offline and move the Unicomp down to my main workstation.
Now, I am a man without a one-loved switch. I have a Das with Cherry blues. That's not the answer either.
I am sad.
bp
:: Leopold FC660C (x2), FC660M (browns), Realforce 87U, Das Keyboard (blues), Matias Tactile Pro (v1), HHKBL2, Matias Quiet Pro, Unicomp Classic 101, Focus FK-2001, Corsair Vengeance K65 (reds), Steelseries Apex 7 TKL ("browns")
:: Modest photo gallery of my keyboards
Offline TotalChaos
  • Indy Game Coder
Re: Unicomp, Matias destroyed my Realforce :-(
« Reply #1 on: Sun, 18 November 2012, 20:35:10 »
Could you please measure the tops of your realforce keycaps for us?
Please measure the tops of your other keycaps too.
I am really interested if the caps are smaller.  You are the second person I have seen saying this.
Thanx
Offline daerid
    • Rossipedia
« Reply #2 on: Sun, 18 November 2012, 20:52:05 »
Odd, I find I am more accurate on my Topre boards. Looking at the caps, they look exactly the same size as my cherry boards, too :-\ Can't say the same for any Alps boards, as I have none :(
Offline FoxWolf1
  • 154
« Reply #3 on: Sun, 18 November 2012, 21:08:23 »
Maybe you're getting used to using heavier switches? If the Topres are now too light for your changed typing style, that would explain having lots of errors.
