Author Topic: Let's make Universal Keyboard a reality  (Read 5491 times)
Offline HenriH
« on: Mon, 19 November 2012, 12:44:44 »
Hi!
I added my idea to Quirky: http://www.quirky.com/ideations/339699
If you like the idea, you can vote it. You can also add comments and suggestions to further improve the Universal Keyboard! Thanks!
Offline esoomenona
  • Gnillort?
Re: Let's make Universal Keyboard a reality
« Reply #1 on: Mon, 19 November 2012, 13:19:28 »
How much do you think it would cost for all of those little e-ink displays?
Offline HenriH
« Reply #2 on: Mon, 19 November 2012, 13:20:59 »
Actually, more like six wide E Ink displays. Controlling over 100 small E Ink displays would be too difficult and expensive.
I guess it's affordable. Probably lots of cheaper than having 100 OLED displays...
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 19 November 2012, 13:27:36 »
I don't think you would be able to see them properly, what with the switch right there. Have you ever pulled caps off of a keyboard and looked at it? I don't mean to degrade your idea, but I'm just not seeing it...
Offline HenriH
« Reply #4 on: Mon, 19 November 2012, 14:36:57 »
I have seen pictures of keyswitches. I haven't dismantled my keyboards...
PS. I updated the images...
Offline esoomenona
  • Gnillort?
« Reply #5 on: Mon, 19 November 2012, 16:27:36 »
So you want the e-ink displays to be 6 strips across the board? Can they handle the flexing over and over like that?
Offline HenriH
« Reply #6 on: Mon, 19 November 2012, 16:39:29 »
Yes, 6 strips.
I have seen flexible E Ink, yes, but my keyboard doesn't need flexible E Ink displays. They can be rigid.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Mon, 19 November 2012, 16:42:37 »
Sorry if I'm asking stupid questions, I just want to understand.
How would they be rigid? From what I see, you want them stripped under the caps. The caps themselves move up and down with the actuation of the switch itself, right?
Offline HenriH
« Reply #8 on: Mon, 19 November 2012, 16:51:21 »
No problem! It's good that somebody is asking questions. :)
This image should clear things up.
When you press the upper keycap down (see the third key from the left which is pressed down), it goes closer to the E Ink display, but it barely touches it. When you release the key, the lower keycap goes up and closer to the E Ink display, but it barely touches it (see the first, second, and fourth keys which aren't pressed down).
« Reply #9 on: Mon, 19 November 2012, 16:51:44 »
I too have a hard time understanding how any continuous piece bridging from switch to switch would not have a deleterious effect on the action of any type of mechanical switch.
Maybe if it was scissor switches with extremely short throws, and a very flexible substrate ....
- D Trump 2026-10-24
Offline FoxWolf1
  • 154
« Reply #10 on: Mon, 19 November 2012, 18:14:45 »
Won't this system mean that you have to increase the height of each keycap by the travel of the switch, in comparison to a regular keyboard (which just has what you label "lower keycap")? If so, you may run into issues with key wobble, as well as the sheer height of the keyboard making it hard to type on.
Offline esoomenona
  • Gnillort?
« Reply #11 on: Mon, 19 November 2012, 18:21:49 »
Ah, I see that now. That image was a little hard to understand. Maybe if the e-ink display part of it was a bolder/brighter color so it was more visible. Then, that does lead me to FoxWolf1's concern: the height would have to be increased. And as it is, people seem to have trouble with mechanical keyboards being the height they are now...
« Reply #12 on: Mon, 19 November 2012, 20:51:45 »
And then, there is that whole "bottoming out" thing that bothers a lot of people.
I just can't see this happening with buckling springs, because the overall height of the assembly would be so great, and all the travel would all have to take place above the display strip.
IBM figured this all out 3 decades ago when they allowed their keycaps (and even barrel springs) to be rearranged. But it has to be done by hand each time.
