Author Topic: Best Lubricant for Cherry Switches?  (Read 4402 times)
Offline firebt
« on: Mon, 19 November 2012, 15:12:00 »
Hey, wanted to know what's the best lube for cherry switches, and how often it should be done. I've been looking at some dry-film teflon PTFE type lubricants that end up dry, but a lot of them have some acetone in it, which is very well known to dissolve many plastics and other organic substances.  I've seen the KG-8 which is also a good choice it seems, but can't find any MSDS data on it.  Anyways, let me know, I have Cherry MX Reds, but I want them to be as smoooooooth as possible :)
Offline TheProfosist
  • Custom Layouts Only!
Re: Best Lubricant for Cherry Switches?
« Reply #1 on: Mon, 19 November 2012, 15:27:05 »
Krytox
Offline SmallFry
« Reply #2 on: Mon, 19 November 2012, 15:38:30 »
Elaborating on what TheProfosist said, Krytox GPL-205 is used typically for the sliders and the GPL-100 series for the springs. Here is a guide on how to lubricate Cherry MX Switches, lovingly put together by MagicMeatball/MMB/BroCaps. Hope this helps!
Offline modulor
« Reply #3 on: Mon, 19 November 2012, 15:50:36 »
Krytox GPL variants (100, 103, 105, 205 etc.) are said to be the best easily accessible lubricants available in the US.  I've tried SuperLube once just because I already had some, and it seemed to make an improvement, but I've not tested it long term yet.  Some other members have had mixed reviews of it, so we'll see.  You can refer to to the MX Lubrication Guide for more info:
http://geekhack.org/index.php?topic=34332.0
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-1000HBU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Tue, 20 November 2012, 00:41:57 »
You're not going to want GPL-100. It's too volatile. 102 or higher should be fine. These krytox are pretty expensive and hard to source, especially the oil variants. The GPL-103 I bought was over $40 for just 1oz.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #5 on: Tue, 20 November 2012, 00:55:53 »
I like a 50/50 mix of krytox 203 and 103 grease and oil, respectively, for the sliders.  For the springs I used Redline 95W75 gear oil (with LSD additives).
Offline jeroplane
« Reply #6 on: Tue, 20 November 2012, 01:33:05 »
Also, an important note, firebt. From your previous posts, it looks like you have a Ducky Shine? Since it's plate-mounted, you won't be able to open up the switches to lube them without desoldering every one...
My signature hasn't changed since 2012. I should really update it.
Re: Re: Best Lubricant for Cherry Switches?
« Reply #7 on: Tue, 20 November 2012, 01:35:37 »
and dont forget the leds
Offline firebt
« Reply #8 on: Tue, 20 November 2012, 05:41:43 »
Aww goddamnit.  Okay, yeah and the LEDs, got it.  It's dual-layer PCB mounted, not sure what that means. How do you remove the bottom side of the keyboard? I'm only asking because I want to eventually clean it out in the future but not break stuff.  And is desoldering really hard? I'm pretty handy and have done some electronics soldering, including building a small radio transmitter when I was really young.  If there are any walkthroughs on the disassembly of a Ducky then I would really appreciate it.
Oh, and also, there is no way to just lube the sides of the sliders by removing key cap, depressing the key and putting a little lube on the sides?  That's how I was about to approach it.  Thanks again guys :)
« Last Edit: Tue, 20 November 2012, 06:21:06 by firebt »
Offline jeroplane
« Reply #9 on: Tue, 20 November 2012, 07:30:23 »
WhiteFireDragon has some really helpful videos:
- his review of the Ducky YOTD, where he also takes it apart.
- Ergo Clear mod which shows desoldering and soldering switches.
I'm not sure about pressing the switch down to lube it, though it might be possible. One of the other experienced lubers might have a better answer.
« Reply #10 on: Tue, 20 November 2012, 10:49:07 »
You can spray liquid lube in but its no where near as effective.
« Reply #11 on: Tue, 20 November 2012, 10:56:37 »
For a switch friendly option what would you recommend.  I'm guessing some people would like to know how to properly ghetto lube their boards lol
Offline Bry
« Reply #12 on: Tue, 20 November 2012, 11:43:50 »
I squirted 3 in 1 oil into a mx brown switch (or 12). Don't do it lol.
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline Grimey
« Reply #13 on: Tue, 20 November 2012, 21:59:56 »
Hmmm, I work for a DUPONT owned company, perhaps I should inquire about this.
Erlang your pants off
Offline SmallFry
« Reply #14 on: Tue, 20 November 2012, 22:07:24 »
I was going to ask for some samples because that's all you really need of the 100 series, but I got some elsewhere. :D
Offline firebt
« Reply #15 on: Wed, 21 November 2012, 01:36:57 »
hahahah i wont.  isn't that oil like very high percentage of petroleum loll
any US store type brands I can get easily around here?  I don't personally like the liquid ones, I'm lookin for KG-8 maybe.   Has anyone had any experience with that?
