Author Topic: Really tight keycap fit on MX clear stems?  (Read 777 times)
Offline BoxWithADot
« on: Wed, 21 November 2012, 23:01:38 »
So I've put ergo clears on my KBT Race and one thing that really bothers me is the extremely tight fit of the keycaps on the stems. When I pull keycaps off of the board they usually pull the switch apart (the top housing comes off the bottom and the stem stays firmly in the keycap). I know it is the stems causing the problem because all the keycaps I try on it fit fine on my other boards. Is there any trick or solution to fixing this issue?
Offline WhiteFireDragon
    • youtube
Re: Really tight keycap fit on MX clear stems?
« Reply #1 on: Wed, 21 November 2012, 23:31:03 »
When I did ergo clears, the brand new stems were really tight too, so the point that I felt I'd rip off the whole switch if I pulled on the cap any harder.
  • Swaglord Yolomancer
  • beekeeper
« Reply #2 on: Wed, 21 November 2012, 23:59:57 »
Same experience here.. I don't rip the top housing off though plate mounted
(Forever) Illustrious.
Offline laffindude
« Reply #3 on: Thu, 22 November 2012, 03:54:22 »
The stem seems to form fit after having caps on them after awhile. Same with the caps. You could try a tiny dab of lithium grease on them if you need to remove it that often.
Offline brianvoo
  • Poisoned
« Reply #4 on: Fri, 28 December 2012, 11:07:43 »
Is there some way to sand down the keycap hole?
Offline brianvoo
  • Poisoned
« Reply #6 on: Fri, 28 December 2012, 11:33:56 »
Yes, the tool is called "file"
There's one that small?
Offline asura
  • not a duck
« Reply #7 on: Fri, 28 December 2012, 11:46:36 »
Look for needle file or jewellers file, should find one that fits - if memory serves the cruciform void is 1.3mm wide.
Another option is to wrap sand paper around a needle or other suitably thin object, and use that.
