Author Topic: Is it ok to use Methylated Spirits to clean PBT dye sub key caps?  (Read 4517 times)
Offline Harlequin
« on: Fri, 23 November 2012, 08:12:38 »
I'm just curious abt Methylated Spirits if i can use it on PBT dye sub key caps to clean
DK Saver Winkeyless | Leopold FC700R | Ducky DK9087 Shine 2
Re: Is it ok to use Methylated Spirits to clean PBT dye sub key caps?
« Reply #1 on: Fri, 23 November 2012, 17:48:55 »
I wouldn't.  I'd soak them in denture tabs according to the instructions.  And scrub with a toothbrush to remove stubborn stains.
Offline TotalChaos
  • Indy Game Coder
« Reply #2 on: Fri, 23 November 2012, 19:23:57 »
R u trying 2 clean ur keyboard?  Or get it into bed with u?  ;D
Do keycaps get hangovers?  :p
Offline Harlequin
« Reply #3 on: Tue, 27 November 2012, 07:22:38 »
i would sleep with my keyboards if i can ;) hahaha
i guess i should just use dental cleanser thing..
