Author Topic: Typewriter keys retrofit?  (Read 11139 times)
Offline fl0w3n
« on: Sun, 25 November 2012, 02:35:04 »
I love the looks of the old plastic, cupped, thick typewriter keys.
I.E.
I'm wondering if anyone has ever attempted to retrofit them onto a newer board?
I'd love to attempt this, but even as difficult as getting the standard alpha numeric keys to fit, getting modifiers would be insanely unlikely.
Anyways, I just wanted to see if there was any discussion to be had regarding this idea.
Or maybe some vintage keyboards that I could look into with these style caps, that can be used on a PC.
Re: Typewriter keys retrofit?
« Reply #1 on: Sun, 25 November 2012, 02:53:01 »
Dat R!
Anyway, pic of the underneath???
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #2 on: Sun, 25 November 2012, 04:22:08 »
I know people do MX stem modding with old Cherry caps locks, I'm wondering if you could do the same to these and fit MX stems on them...
Offline TotalChaos
  • Indy Game Coder
« Reply #3 on: Sun, 25 November 2012, 05:08:52 »
@flow3n
We need upskirt shots to determine gender and so forth.
p.s.  The keys in your pic have "spherical" tops.  Because they have a spherical indentation.  You can put a marble on top of your key and it will not roll off.  I want to get spherical keys too.  But the only kind I can find anywhere have cylindrical tops.
Offline GMC
  • Shiny.
« Reply #4 on: Sun, 25 November 2012, 05:48:55 »
Signature plastics can do spherical profile. I've got a space cadet style set coming in the round 4 group buy on Deskthority. Head over there and see if there are leftovers.
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline TotalChaos
  • Indy Game Coder
« Reply #5 on: Sun, 25 November 2012, 06:09:49 »
@GMC
You just exploded my brain.  :eek:
I could have got Spherical keys as all row 3 ?
Am I understanding that right?
So all the keys would be interchangeable?
I could rearrange my keys to try Dvorak or Colemak, etc. if all keys are in Row 3 profile, correct?
Offline GMC
  • Shiny.
« Reply #6 on: Sun, 25 November 2012, 06:56:01 »
You'd have to contact 7bit to be absolutely sure but looking at the wiki, I think mods are all row 3 but alpha might be stepped, see sp website faq for an image of the sa series
Round 4 set illustration
Offline BLJ Consulting
  • Independent Plastics Consultant
« Reply #7 on: Sun, 25 November 2012, 10:03:47 »
@GMC
yes at SP we have the tooling for these spherical keys both 1st and 2nd shot and yes generally it is all row3 that is ordered.  we use them mostly for industrial customers but occasionally GH'ers order them
Offline fl0w3n
« Reply #8 on: Sun, 25 November 2012, 12:37:17 »
Got any pictures of what these look like?
Also, this eBay listing has a nice clear shot of the underside.  It looks like they could have a little "tongue" made, and possibly fit that into the keycap and then the other end into Alps?  For Cherry, it would need some real handy dremel work.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #10 on: Sun, 25 November 2012, 13:16:10 »
Does that change pricing, or did I just ask a Melissa question?
 - Ron | samwisekoi
Offline fl0w3n
« Reply #11 on: Sun, 25 November 2012, 13:52:55 »
Hmm, there are some SA profile (One of the SP spherical profile codes) sets here, http://keycapsdirect.com/key-capsinventory.php
But when it says there are XXX qty of keys in XXX color, does that mean they are blank or just a jumble of legends or what?
Offline fl0w3n
Offline Hak Foo
  • Make America Clicky Again!
« Reply #13 on: Sun, 25 November 2012, 21:47:48 »
I think someone played with the 64's caps, and while similar to the Cherry stem, they're not quite the same.
Overton130, Box Pale Blues.
Offline fl0w3n
« Reply #14 on: Sun, 25 November 2012, 22:21:37 »
Damn, those look pretty sweet too.
I'm not interested if anyone can show me what SP's spherical keys look like...I may be interested in putting together my first GB if they look right.
« Reply #15 on: Mon, 26 November 2012, 18:17:59 »
[/quote]
[/quote]
grey is the SA series which i think is what you are looking for, black #3 is DSA, white/red escape is DCS row1
sorry the photos arent great.
Offline fl0w3n
« Reply #16 on: Mon, 26 November 2012, 18:33:06 »
I think you're right, from the pictures the F2 may be close to the style I'm looking for.  Based off your sketches of keys on the site, SS series may also be close.
Offline TotalChaos
  • Indy Game Coder
« Reply #17 on: Tue, 27 November 2012, 01:43:34 »
Why does the gray Fkey look so tall?  It looks like OEM profile?
I never heard that SP could make OEM profile keys....
Offline jeroplane
« Reply #18 on: Tue, 27 November 2012, 14:36:56 »
It's part of their spherical series, not cylindrical.
My signature hasn't changed since 2012. I should really update it.
Offline TotalChaos
  • Indy Game Coder
« Reply #19 on: Thu, 29 November 2012, 11:10:08 »
What is the height of their spherical series?  12mm?
« Reply #20 on: Sat, 01 December 2012, 13:42:29 »
I know it won't help much, but IBM Selectric keys will fit on a beam spring.
From what I have seen, modding these to fit on a cherry KB is really difficult, you need to hollow out the stem to fit the + of the cherry key, then you need grind away plastic until it's narrow enough to fit in a cherry keyswitch without hitting the top of the switch housing.
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #21 on: Sat, 01 December 2012, 20:34:19 »
album: http://imgur.com/a/ZBmCn
some old cherry spherical doubleshots i pulled from a microscope keyboard i received a month or so ago.  they'll fit onto an MX stem but they won't go down into the switch housing, of course.  these would presumably be easier to modify to be compatible -- any good methods to go about this, or is it something no one has ever really gone through with?
« Last Edit: Sat, 01 December 2012, 22:09:46 by precarious »
