Author Topic: [IC] Moogle Kit R4 GB (ON HOLD)  (Read 76439 times)
Re: [IC] Moogle Kit GB
« Reply #50 on: Mon, 26 November 2012, 21:42:50 »
You run the GB, you can call it as you like. :D
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #51 on: Mon, 26 November 2012, 22:07:03 »
Hmm 1.75x right shift and "~`" in R4 for KBT Pure compatibility.
Offline fl0w3n
« Reply #52 on: Mon, 26 November 2012, 22:35:43 »
Just throwin this out there, since we have so many keys, why not add \| and `~ like the RA 2.0 sets :s
I know these are seen as "alpha keys" but I like how those two combined create a full 'wrap' around the alpha characters.
Like I said, just my $.02 :)
I was thinking the same thing. Some wyse sets need those keys anyways.
I'm considering getting in on this despite not needing anything currently.
Offline gizmo
« Reply #53 on: Mon, 26 November 2012, 22:36:54 »
In for a WYSE
Offline dreamingftw
« Reply #54 on: Mon, 26 November 2012, 22:47:05 »
filled out for white on black and black on beige
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #55 on: Mon, 26 November 2012, 22:59:50 »
I want a Hastanga kit.
-Enzo Ferrari
Offline sth
  • 2 girls 1 cuprubber
« Reply #56 on: Mon, 26 November 2012, 23:00:57 »
and for dolch.... zombhastanga!
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #57 on: Tue, 27 November 2012, 01:56:57 »
A 7x spacebar may end up being useful for some GH60 layouts. We'll have to see. ;)
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #58 on: Tue, 27 November 2012, 02:09:18 »
Hmmm, filled out the form, just added +2 to both dolch and beige :D
Offline BimboBB
« Reply #59 on: Tue, 27 November 2012, 02:51:41 »
The Koreans will be interested for sure.  Make sure to choose a better white color than I did. :P
any help would be greatly appreciated in color choice.
imo, the beige spacebar (not the white one) from WASDkeyboards.com comes very close to the white cherry caps. But not sure if he works with SP colour codes.
example with cherry caps and wasd spacebar
Offline rayuki
  • RAAAAAAR
« Reply #60 on: Tue, 27 November 2012, 06:08:28 »
Make sure to include spacebars as a separate option so that owners of R3 moogles can get a better color match without buying a whole new set.  Also, please brand these as "round 4", "R4", etc. to identify continuity with previous sets. ;)
sounds good thanks hash will brand this R4 when ordering goes ahead. (im sure it wont be long now the IC form is getting big lol)
will make some adjustments to all the different sets and get everything up soon.
thanks for the pics blighty
Offline shawn o
« Reply #61 on: Tue, 27 November 2012, 08:03:56 »
YEs, please make a new white spacebar that actually matches the white moogle keys. Also center stemmed, stepped caps lock in Dolch and WYSE.
Offline rayuki
  • RAAAAAAR
« Reply #62 on: Tue, 27 November 2012, 09:05:42 »
any ideas on color code?
Offline Acanthophis
« Reply #63 on: Tue, 27 November 2012, 09:11:04 »
Those GH60 layouts (1,5 mods + 7 space bar) are designed to fit for a Cherry Corp 2shots. And they all do have a 7 space bar, even a better one than those edged ones SP produces...
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Re: [IC] Moogle Kit GB
« Reply #64 on: Tue, 27 November 2012, 09:21:33 »
I'll take some pictures of my samples  tonight and look up the codes I used for the other colors.
Offline rayuki
  • RAAAAAAR
« Reply #65 on: Tue, 27 November 2012, 09:37:20 »
awesome thanks hash. so far numbers are promising after only a day :)
Offline Alessandro
Re: [IC] Moogle Kit GB (Updated IC count 28/11)
« Reply #66 on: Tue, 27 November 2012, 09:53:09 »
This is moving nice and quickly! Well done!
Offline fl0w3n
« Reply #67 on: Tue, 27 November 2012, 10:24:43 »
So fast that I may have 4 moogle sets and no keys to use them on haha
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #68 on: Tue, 27 November 2012, 10:26:14 »
Like already mentioned on DT, a dolch stepped capslock would be cool
Offline fl0w3n
« Reply #69 on: Tue, 27 November 2012, 10:27:27 »
Yea I'd love a stepped caps for my current WYSE moogle
« Reply #70 on: Tue, 27 November 2012, 10:33:56 »
It's been said before, but when it comes to keycaps and accessories, you should buy when you have the opportunity. Not for what you currently have, but what you might want in the future. Better to have something you don't really need right now, than need something you can't get later.
For instance, you might think you'll never have or even want a Korean custom keyboard, so you have no need of a tsangan compatibility kit with your keyset purchase. Then later, when you finally obtain one of them, you regret not having the correct keys for the bottom row.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #71 on: Tue, 27 November 2012, 10:34:02 »
It's time to convert this into the GB as you have enough for MOQ =)
-Enzo Ferrari
Offline Alessandro
« Reply #72 on: Tue, 27 November 2012, 10:34:34 »
W00P! This is looking good!
Offline Shadovved
« Reply #73 on: Tue, 27 November 2012, 10:35:38 »
GB GB!
Offline rayuki
  • RAAAAAAR
« Reply #74 on: Tue, 27 November 2012, 10:50:49 »
from the price quote i got from Melissa im going to include both stepped and center-stemmed caps in the base sets for all kits as it doesn't add much extra.
im going to get a few more quotes on some different sets that others have mentioned and see if we get enough interest when i put up ordering to get them.
GB will go into ordering once all quotes are finalised for the sets im looking at and i figure out color codes and fonts (i want it all sorted first before going into ordering phase so i can have it all in the OP to keep it organised)
should only be a few more days at the latest this thing is moving fast so get on the train choo choo!
Offline fl0w3n
« Reply #75 on: Tue, 27 November 2012, 11:00:19 »
That gets expensive FAST :(
I.E. I'm likely going to get all 4 sets here...that's $80 for just Moogle, which means then I'm keeping my eye out for the set's themselves (minus my WYSE) and at a low of $50 a set...!
But I 'spose I do agree.
« Reply #76 on: Tue, 27 November 2012, 11:05:18 »
Welcome to wallethack. You are now poor.
Quote stolen from hashbaz. :)
« Last Edit: Tue, 27 November 2012, 11:21:06 by jdcarpe »
Offline rayuki
  • RAAAAAAR
Re: [IC] Moogle Kit R4 GB (Updated price list 28/11)
« Reply #77 on: Tue, 27 November 2012, 11:14:45 »
i've added updated price list for the "BASE" kit i want to do for each set.
also getting quotes on the following:
Anti-Caps Kit: for swapping control and caps lock.
1 x Control (1.75x)
1 x Caps-Lock (1.25x)
ISO Adapter Kit:
1 x Enter
1 x Backslash/Pipe
1 x ISO left Shift (1.25)
anything else i should add to get quotes on before moving this to ordering?
Offline hashbaz
  • Grand Ancient One
« Reply #78 on: Tue, 27 November 2012, 11:26:59 »
Is your ISO adapter kit for using an ANSI set on an ISO keyboard?  If so, you should probably just call it an ISO kit since that is what they are usually called.  Also, "ISO adapter kit" in the R3 moogle buy was the opposite, adapting an ISO set to work on an ANSI board.
Offline el2k
« Reply #79 on: Tue, 27 November 2012, 11:29:05 »
In for one of each.
sc00pz for life
Offline rayuki
  • RAAAAAAR
« Reply #80 on: Tue, 27 November 2012, 11:35:01 »
yeah i pretty much just copied it from your R3 using the pics at DT for:
Anti-Caps Kit: for swapping Control and Caps Lock
ISO Adapter Kit: for using an ISO Cherry set on an ANSI keyboard
should i do both? gah so confusing and this being my first GB lol.
also thinking of doing like a full wrap kit:
1 Tab
1 Backspace
1 Enter
1 ~
1 \
« Last Edit: Tue, 27 November 2012, 11:39:09 by rayuki »
« Reply #81 on: Tue, 27 November 2012, 11:38:10 »
also thinking of doing like a full wrap set with Tab ~ \ Backspace. thoughts?
Tab, Backspace, and Enter make up "full mod kit." You could add ~ and \ to the base set if you wanted.
Offline rayuki
  • RAAAAAAR
« Reply #82 on: Tue, 27 November 2012, 11:40:40 »
ok sounds good if people are happy with adding ~ and \ to base set it shouldn't be much extra and i'll just do the normal "Full mod kit"
as well as the proper ISO KIT (what is this excactly, fat ISO enterkey?)
also single spacebars as requested.
lots to add!
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #83 on: Tue, 27 November 2012, 11:50:24 »
In for 1 and can help for usa shipment :)
Are you sure you won't be tired after the Valentine sets? =)
Offline hashbaz
  • Grand Ancient One
« Reply #84 on: Tue, 27 November 2012, 11:50:28 »
Wait, why would you add ~ and \ to the base kit?  That makes no sense to me.
Offline rayuki
  • RAAAAAAR
« Reply #85 on: Tue, 27 November 2012, 11:53:11 »
add it to the FULL MOD SET then like i was originally going to do and call it "FULL WRAP SET" to get what people want out of those keys anyway lol.
someone said something about it being part of RA 2.0 Base set.
either way nothing is set in stone yet just getting ideas so i can figure out what the final lineup will be.
« Reply #86 on: Tue, 27 November 2012, 12:18:33 »
Ragnorock started this with his RA2.0 GB. Makes it so the contrasting modifiers completely wrap around the alphanumerics. SP has followed suit with their "stocked" modifier kits. I personally don't like it, since traditionally those keys are the same color as the alphanums. But I guess some people prefer it.
Offline blighty
« Reply #87 on: Tue, 27 November 2012, 12:20:58 »
Mayhap wait and see what GMK (the maker of Cherry's doubleshots) says on pricing and MOQs?
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Shadovved
« Reply #88 on: Tue, 27 November 2012, 13:25:17 »
Yeap, ride on the GMK bandwagon!
Offline rayuki
  • RAAAAAAR
« Reply #89 on: Tue, 27 November 2012, 15:30:23 »
heres the color thing from SP
GX is the modifiers for dolch
Offline hashbaz
  • Grand Ancient One
« Reply #90 on: Tue, 27 November 2012, 15:37:37 »
I just dug through my email history, here are the colors I used for the last round.  I think they're all a really good match except for the NN on WFK white keys.
Black: WFK on NN, NN space bar
White: NN on GAW and NN on WFK, WFK space bar
Dolch: WFK on GEW, GE space bar
Offline gizmo
« Reply #91 on: Tue, 27 November 2012, 20:30:41 »
Currently just in for one WYSE, but can certainly justify a few more sets if it changes price tiers.
Offline BimboBB
« Reply #92 on: Wed, 28 November 2012, 02:49:40 »
have compared the wasd-space with the original cherry one. the wasd-space is more white than i thought. But have seen a picture where someone compared the CCnG space with the original one and its nearly the same color. (cant find that anymore) This cream cheese color code was WCK.
Offline jeroplane
« Reply #93 on: Wed, 28 November 2012, 04:57:35 »
It all depends on the quality of your set and lighting. Personally I think CCnG was the best match. The WASD light grey still looks a bit too grey to my eyes, and I'd rather err on the white side than the grey side of the scale.
My signature hasn't changed since 2012. I should really update it.
binarystar9
  •  Guest
« Reply #94 on: Wed, 28 November 2012, 05:24:06 »
dolch!
in
Offline SmallFry
« Reply #95 on: Wed, 28 November 2012, 07:59:48 »
Are you thinking of trying to use the i3oilermaker's new center stemmed caps lock that is stepped? (Pending his permission, O'course)
Offline rayuki
  • RAAAAAAR
Re: Re: [IC] Moogle Kit R4 GB (Updated price list 28/11)
« Reply #96 on: Wed, 28 November 2012, 08:44:48 »
Hmm no I wasn't aware of it. We have plenty enough keys for now though I may add it as an extra. Will try and get some mockups done today and get color codes finalised before putting it into full GB ordering mode :)
(If anyone can help with mockups please pm me)
Sent from my GT-I9100T using Tapatalk 2
« Last Edit: Wed, 28 November 2012, 09:49:33 by rayuki »
Offline Soulpyre
« Reply #97 on: Wed, 28 November 2012, 11:45:11 »
What fonts will be used for the various sets, just curious.
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline hashbaz
  • Grand Ancient One
« Reply #98 on: Wed, 28 November 2012, 11:46:15 »
I can modify my mockups from R3 to fit your sets.  Also will take some pics of color samples next to real Cherry keys for color choosing purposes.  Gimpster posted some pics that are now buried somewhere in the R3 thread that showed the possible choices for Dolch, and the ones we used were pretty clearly the best.  We could maybe try to find a better gray/beige for the white sets, but I think the previous rounds have been quite good.  The only real question in my mind is choosing a new off-white color for the white kit spacebars and backslashes (and tildes I guess).
Offline rayuki
  • RAAAAAAR
« Reply #99 on: Wed, 28 November 2012, 17:20:44 »
yeah that would be great, i think as others have said the CCnG white spacebar would make a good match. WCK
arn't all fonts just going to be cherry?
