Author Topic: Soft Touch Keycaps?  (Read 4979 times)
Offline TotalChaos
  • Indy Game Coder
Soft Touch Keycaps?
« on: Tue, 27 November 2012, 03:22:13 »
A review of a QPAD MK-85 backlit keyboard said:
Like its predecessor, QPAD have stuck with the soft-touch key-tops. These feel really good to touch, grippy and smooth, and judging from the MK-80 which has been through a lot since its review it is a surprisingly durable finish. The lettering on the keyboards is transparent. When used in daylight the lettering still retains a good amount of visibility without turning on the lights. For use in dim rooms the lighting feature makes sense.
I don't care one way or the other about backlighting.
The soft touchiness sounds very interesting.
Is there a name for this type of keycap?
Do they last?
Where can I find other keyboards with keycaps like this?
Can I buy such keycaps?
Offline Vintage
Re: Soft Touch Keycaps?
« Reply #1 on: Tue, 27 November 2012, 14:14:13 »
Pretty much every backlit keyboard has a "soft touch" coating on the keys. So that includes the Razer BWU, Duck Shine II and YOTD, Qpad, Logitech G710+, etc. I think the CM storm QFR and Rosewill non-illuminated both have similar coatings on their keycaps.
It has to do with the enamel that they use to make the non-legend part black instead of clear.
The legend will last a pretty long time but they will shine like any other ABS cap.
I think that Ducky is supposed to release custom translucent legend keys soon, but other than that IDK any places you can just get the keycaps. Someone else here might.
« Last Edit: Tue, 27 November 2012, 14:19:03 by Vintage »
CM QFR w/ MX Reds  | Logitech G900
