Author Topic: Cherry MX Red Esc Key with WNV keys *doubleshots*  (Read 2533 times)
Offline inlikeflynn
  • file not found
« on: Tue, 27 November 2012, 17:38:29 »
Cheaper than any of the recent auctions and with the WNV keys too
http://www.ebay.com/itm/Cherry-MX-Red-Esc-Key-with-WNV-keys-doubleshots-/300825149707?pt=PCA_Mice_Trackballs&hash=item460a93810b
look at the location  ::)
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline damorgue
    • Personal portfolio
Re: Cherry MX Red Esc Key with WNV keys *doubleshots*
« Reply #1 on: Tue, 27 November 2012, 17:42:40 »
If the whole GMK thing goes through, the value of some of the most valuable keys will decrease quite a lot. Sure, some will still want the originals, but it might be hard to tell them apart, and a lot of the demand may disappear.
Edit: The potential production of SSKs might cause the same effect there too.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Tue, 27 November 2012, 17:47:02 »
On the cherry stuff yes, I think if GMK does start to make "cherry caps" again could reduce prices on original cherry stuff by quite a bit. But I'm also sure there will still be people how stick to 1980-1990 cherry stuff only just because they're purist.
However on the SSK, it will be a Model M/it parts modded to SSK/TKL layout, but it won't have the OEM case. I think kawa is looking at an acrylic case since OEM cases are near impossible to find with any large quantity.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #3 on: Thu, 29 November 2012, 14:00:14 »
Who bought these?
Offline inlikeflynn
  • file not found
« Reply #4 on: Thu, 29 November 2012, 14:06:03 »
Who bought these?
they weren't. seller took them down ebay says:
"This listing was ended by the seller because the item is no longer available."
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline DanGWanG
  • Higher Standards
« Reply #5 on: Thu, 29 November 2012, 14:14:29 »
Ah, OK.  Hopefully relisted at a cheaper price =)
