Author Topic: 1 unit Bottom Row Modifiers  (Read 3681 times)
Offline SmallFry
« on: Wed, 28 November 2012, 00:05:49 »
Which keys do you know of that are bottom row 1 unit modifiers?
Example...
Plastic: ABS
Type: Double Shot
Profile: SP profile
Offline inlikeflynn
  • file not found
Re: 1 unit Bottom Row Modifiers
« Reply #1 on: Wed, 28 November 2012, 00:12:33 »
The star/diamond/windows/function from every tsangan kit
the yellow diamond from MBC's RGB kit
The yellow cherry from the dyesub RGB kit
too many to remember from the original RA kit
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #2 on: Wed, 28 November 2012, 00:17:05 »
I have a light blue SP style cap that says 'U4' on it. Modifier row profile. Engraved/infilled PBT style as well.
Are you looking for caps, or just kind of making a database? A database would be kind of helpful actually. For those of lesser knowledge.
« Last Edit: Wed, 28 November 2012, 00:21:27 by Halverson »
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #3 on: Wed, 28 November 2012, 00:18:26 »
DDR up and down
Offline SmallFry
« Reply #4 on: Wed, 28 November 2012, 07:34:46 »
I'm looking for some, but also making a thread/database. I want something to go with my Graphite set.
The Up arrow is also the bottom row? Or is just the Down, Left, and Right the bottom row?
« Last Edit: Wed, 28 November 2012, 07:39:34 by SmallFry »
« Reply #5 on: Wed, 28 November 2012, 07:38:47 »
Yes all arrows have the same profile.
« Reply #6 on: Wed, 28 November 2012, 07:42:28 »
Name: Mystery Keycap #2
Plastic: ABS
Type: Double Shot
Profile: SP profile
« Reply #7 on: Wed, 28 November 2012, 07:46:07 »
Name: the <, and >. keys from any set
Plastic: varies
Type: varies
Profile: varies
Offline Lu_e
« Reply #8 on: Thu, 29 November 2012, 02:11:05 »
Name: Crystal (from Br Ba)
Plastic: Polycarbonate (semi-transparent)
Type: Single shot
Profile: SP profile
Just say NO to ABS keycaps
