Author Topic: Broke Leopold Spacebar  (Read 4243 times)
Offline deegaf
« on: Thu, 29 November 2012, 16:44:37 »
Hey guys, I accidentally broke one of the switches for the Leopold spacebar.  Problem is, this board seems to be epoxied and I can't even remove the plate from the back cover. Anyone had experience taking a Leopold apart?
Offline 1391401
  • MX CLEAR
Re: Broke Leopold Spacebar
« Reply #1 on: Thu, 29 November 2012, 19:06:44 »
I believe all of the switches must be desoldered in order to remove the switches and the plate to perform the fix.  Some plates have a space where you can wedge a tool in there to open the top of the switch and replace the innards but I do not believe those are available on any standard keyboard.
edit: you did say 'one of the switches for the spacebar' did you perhaps mean the stabilizers to the right and left the switch?  They kind of look like a small switch in a way... it might be possible that you dislodged the stabilizer bar and that can be fixed if you have ninja skillz
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline deegaf
« Reply #2 on: Fri, 30 November 2012, 05:45:29 »
Ah, that is it. I meant to say stabilizer the first time, but it's been like 6 mos and I forgot how it looked in there.  But yes, I think I'd have to go under to replace the stabilizer since I broke some other part of the plastic and the plate can't come off.  I'll just buy another keyboard, it's hopeless lol.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #3 on: Fri, 30 November 2012, 05:56:08 »
you need to desolder the switches i believe to get at the cherry stabilizers
Offline TotalChaos
  • Indy Game Coder
« Reply #4 on: Fri, 30 November 2012, 06:33:37 »
@Deegaf
How did you break the spacebar?
A bout of drunken online gaming?  :))
Fight with Mrs. Deegaf?  :-*
I am curious as I have never broken any key on any keyboard in my life despite having dropped many keyboards on the floor many times.  + lots of intense gaming, etc.
« Reply #5 on: Sat, 01 December 2012, 13:54:24 »
Actually, you only need to desolder the one switch. The custom plates are set up so you can replace the switch tops without desoldering at all, but I tested this on several keyboards I was destroying for parts, and you can pretty easily compress the upper and lower wedges holding the switch on once you've desoldered it. You do need to get all the solder off, though.
