Author Topic: Lite Filco a la HHKB Lite?  (Read 2922 times)
Offline Joe6pack
« on: Fri, 30 November 2012, 17:25:26 »
While I was searching where to get a Filco, I came across Filco Excellio Lite Dream keyboard model:
http://www.diatec.co.jp/products/list_mkr.php?mkr_c=34
It does not look like a MX switch keyboard since it is a light and thin keyboard.
Filco has a new model with Metallic blue cover.  Is this a metal cover or just a different paint over the standard cover?
Re: Lite Filco a la HHKB Lite?
« Reply #1 on: Fri, 30 November 2012, 17:30:33 »
Rubber dome. Looks quite similar to the new Dell low profile rubber domes.
If you are referring to the Majestouch AI Metallic Blue, it is a metallic blue painted plastic case.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Fri, 30 November 2012, 17:32:03 »
I doubt it's painted. More than likely just a different plastic used
« Reply #3 on: Fri, 30 November 2012, 17:36:43 »
No, I'm pretty sure the Metallic Blue, Metallic Pink, Camouflage, and Italian Red Filcos are all painted. Someone correct me if I'm wrong.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Fri, 30 November 2012, 17:40:50 »
Hmm, I could see them doing it for the camo (I'm thinking dip paint) but the others you would think they would go with a different plastic.
Offline laffindude
« Reply #5 on: Fri, 30 November 2012, 18:09:58 »
It is a "パンタグラフ" "pantograph" keyboard. AKA scissor board.
Offline whiskerBox
« Reply #6 on: Mon, 03 December 2012, 09:41:23 »
It's too bad "pantograph" is not as cool as it sounds.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
