Author Topic: [IC] GMK Electronics (Cherry OEM) Colored Esc's, Modifier Sets, CMYK, Number Row  (Read 163319 times)
Re: [IC] GMK Electronics - Colored Esc's, Modifier Sets, CMYK, Number Row
« Reply #50 on: Fri, 07 December 2012, 10:08:12 »
That's why you vote for purple...
Offline aggiejy
« Reply #51 on: Fri, 07 December 2012, 10:10:41 »
Well, I just voted for blue across the board. Blue is the only color (besides black, white, grey) that doesn't clash with any other color. But, I'd prefer a lighter blue rather than the RGB blue.  Beggars can't be choosers though. :-)
Offline esoomenona
  • Gnillort?
« Reply #52 on: Fri, 07 December 2012, 10:11:59 »
I haven't voted yet. I'm still hoping I can see the results thus far.
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #53 on: Fri, 07 December 2012, 10:19:02 »
Some really cool colour options there Dan! Hoping the vote is good! Although, that means I'm also hoping some retailers come through with standard mod kits.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #54 on: Fri, 07 December 2012, 10:21:55 »
Still laying in bed but I'll update results thus far later.
Regarding the modifier set, there arent any standard colors because we believe industrial manufacturers and other retailers will be releasing full sets in original colors.  Either that will happen or a future gb on GH will include those mods as part of an original full set.
The modifier pack isnt intended to be a true moogle kit or tsangan kit, but more a holistic unique modifier pack to fit the same profile as your existing sets.
Offline telepete
  • Jedi Knight and friend of Captain Solo.
« Reply #55 on: Fri, 07 December 2012, 10:30:10 »
If you didn't vote [for purple] you are a communist.
Don't you wish Carnifex was at your side?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #56 on: Fri, 07 December 2012, 10:32:46 »
If you vote blue, you can create your own CCnB that everyone's been raving about
But purple is slick too :D
« Reply #57 on: Fri, 07 December 2012, 10:33:14 »
I voted for purple. :D
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #58 on: Fri, 07 December 2012, 10:35:43 »
LOL - In Soviet Russia, keyboard types you!
« Last Edit: Fri, 07 December 2012, 10:37:31 by i3oilermaker »
  • Live long and prosper
« Reply #59 on: Fri, 07 December 2012, 10:36:48 »
FTFY
tp thread is tp thread
Offline Acanthophis
« Reply #60 on: Fri, 07 December 2012, 10:38:11 »
What legends will be used for the mods?
I prefer symbols only over symbols + text.
AFAIK, we haven't discussed this so far but already polling on the colours on legends we don't know how they look?
I think symbols only just look so much better.
Backspace symbol, also used in Round4, IIRC.
Photo from lysol.
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #61 on: Fri, 07 December 2012, 10:57:43 »
I hope black on red isn't a "standard" color! I really want to buy anything that will have a black legend, and none of the options in the poll had that Q_Q
<3 Dan.
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline theultrazord
« Reply #62 on: Fri, 07 December 2012, 11:11:15 »
<3 Dan.
Cheers,
Probably because there was just a cherry profile PBT dyesub groupbuy so a bunch of people already got caps with black legends recently. I'm sure there will be black legends in the future =D.
Offline ekw808
  • Ekw
« Reply #63 on: Fri, 07 December 2012, 11:14:55 »
wow dat purple O_O
[One Keyboard at a time]
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #64 on: Fri, 07 December 2012, 11:23:14 »
The color choices were what seemed to be the most popular suggestions from the earlier thread. If you do not care for those that is why the OTHER box exists. If I see enough of the same things from other choice, I will make it a selectable option.
There is not white/black and black/beige because I thought people would be interested in something new and different and put some color into their life. We will be doing full set in the spring, and of course those colors will be available then.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #65 on: Fri, 07 December 2012, 11:24:33 »
We should do some mockups of the modifier set color choices with black, white, and Dolch alphanums.
« Reply #66 on: Fri, 07 December 2012, 11:40:54 »
Working on mock ups, of course someone can feel free to beat me to it. I meant to get them done yesterday, but kept getting sidetrack.
Offline hashbaz
  • Grand Ancient One
« Reply #67 on: Fri, 07 December 2012, 11:56:21 »
I can repurpose my Red Cherry mock-ups in about ten minutes, though I won't be able to do it until tonight.  If you have any actual color codes that would be awesome.
Offline rayuki
  • RAAAAAAR
« Reply #68 on: Fri, 07 December 2012, 12:33:07 »
oh good lord gravy i want that brown as my modifier set!
would match lovely with almost every set i can think off lol
« Reply #69 on: Fri, 07 December 2012, 12:40:05 »
Looks good hashbaz, just need to remove the text from tab, shift, enter, backspace and use the lock icon for the caps lock key and it would be what we are planning on using legend wise. Some of the colors are in the colorchip photo, otherwise use your best judgement.
Offline Batmann
« Reply #70 on: Fri, 07 December 2012, 12:47:24 »
GMK must have the pantone codes for each colour,
If you could manage to get them that would help a lot imho  :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #71 on: Fri, 07 December 2012, 12:51:28 »
Yesplz.  That way I can make possible adjustments to Klaxon to see if we want a full set that looks like our favorite ESC key.
Offline DanGWanG
  • Higher Standards
« Reply #72 on: Fri, 07 December 2012, 12:51:30 »
I've updated some 'at a glance' results on the 2nd post.  Green, purple, blue and red seem to be the most popular variants.  I'm working on getting the results into a chart in excel and **** so stay tuned after Day 1.
Offline DanGWanG
  • Higher Standards
« Reply #73 on: Fri, 07 December 2012, 12:52:52 »
Right now all their codes and color samples and stuff are filed into decades of folders, unarchived, unorganized, etc.  They're working on getting a digital representation of all their documentation including legends and colors.  We've been promised all that information =)  I just don't think it'll come soon enough...
Offline yuiop
« Reply #74 on: Fri, 07 December 2012, 13:55:57 »
Form filled.  This is pure awesomeness.  Thanks Dan and lysol!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #75 on: Fri, 07 December 2012, 13:58:04 »
I wish I still had access to a pantone book, I'd be able to get numbers fairly easily then.
Offline The_Beast
  • I like wood ಠ_๏
dat purple will make me order anything bro
anything
Offline DanGWanG
  • Higher Standards
Even...women pleasure toys?
Offline The_Beast
  • I like wood ಠ_๏
Especially 'dat
Offline mistakemistake
  • Global Loveinator
^lol..
From what I gathered from the info given regarding colors, is they can source them from several suppliers, and color codes can differ from place to place for the same color. So using something that is standard like RAL or Pantone would probably be a good idea and they can use that info for closest non custom color. If hell bent on exact shade, custom color can be had, but the price could be quite high.
Offline Alessandro
Considering how great the prices are I'll be down for a few of everything if it helps reach the MOQ.
Offline TheProfosist
  • Custom Layouts Only!
Voted and we should go for the 7x spaces
Offline Alessandro
7x space will be awesome, especially if we get it at the same time as the GH60.
We need more votes for purple! Yes, I am biased.
Please refrain from ballet stuffing however, having your dead relatives vote for your favorite colorway is not cool. Also, if I notice someone enter multiple times I will invalidate all of your votes. :) Play fair.
Offline Alessandro
But now I want to vote for purple and I can't. :(
Offline Batmann
Offline DanGWanG
  • Higher Standards
Let's stay on topic please =)  (even though I was the one who started it...)
Offline Soarer
Please refrain from ballet stuffing...
Offline keyboardlover
Voted! This is amazing.
Offline DanGWanG
  • Higher Standards
Get your votes in.  Voting ends Tuesday
Get your votes in for purple.  Voting ends Tuesday
FTFY
« Reply #92 on: Sat, 08 December 2012, 10:38:50 »
FTFY
Purple n green, purple n green.
Erebody wants to smoke some o' dat purp n green
Offline Alessandro
Needs more Barney keycaps.
Offline el2k
Filled out :D
sc00pz for life
Offline Acanthophis
Photo from lysol.
Classic symbols without text as found on most European set. In my photo it shows a DELETE key, which is not included in this pack. Backspace will have the left pointing arrow.
That photo is however an excellent example of what the white on green set would look like.
Caps lock will have the lock icon not 'caps lock' on it.
Offline asura
  • not a duck
Mmmmmm, number row without symbols now that would be nice!
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Hand bag caps lock?  ;D
Numrow without symbols is what my original idea was for the numrow pack so it would be universal. I also think it is more aesthetically pleasing as it is uniform with the alpha keys.
Correct the 'hand bag' lock icon.
Very funny Soarer, the autocorrect took over in a wrong way. It should have been ballot obviously.
« Last Edit: Sat, 08 December 2012, 12:21:22 by lysol »
