Author Topic: PEXON Cables- 10% off, Free MDPC and Cheaper Pricing!  (Read 215564 times)
Offline Grim Fandango
Re: PEXON Cables- 10% off, Free MDPC and Cheaper Pricing!
« Reply #450 on: Fri, 21 June 2013, 16:05:51 »
Got my cable today! I love the look of these MDPC cables.
Really happy with it.
Pexon, do you have any more tips for what we could use as a stress relief. Right now, this is what I did
I think it works well enough, though I was thinking of maybe adding a proper one.
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #451 on: Fri, 21 June 2013, 16:15:23 »
Thats what I use, I am looking at other methods, but a cable tie is more than adequate
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #452 on: Fri, 21 June 2013, 17:13:48 »
Got some new colours in, they are all in a MATT finish, no shine on these bad boys.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #453 on: Sat, 22 June 2013, 06:07:44 »
What kind of cables are those? MDPC, Paracord or something else?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #454 on: Sat, 22 June 2013, 06:14:43 »
Something new mate, it's a matte style sleeve
Offline Mysteric
  • Formerly 'Mackem'
« Reply #455 on: Sat, 22 June 2013, 08:11:47 »
If you have the charcoal grey Paracord, how much for a 2M cable in that for my Quick Fire Rapid?
Also, do you use plastic USB housings on the mini USB side? I ask because there is limited space around near where the mini USB plugs in so if the housing is too 'bulky' it may cause the connector to be 'angled'?
I was also wondering if Paracord would fit into the cable routing system the QFR has going on
http://whatswithjeff.com/wp-content/uploads/2012/03/cm-storm-quick-fire-17.jpg
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #456 on: Sat, 22 June 2013, 09:24:36 »
Yea it will fit in no issues. If you order on the site www.pexonpcs.co.uk, it will be 15 GBP
Offline Mysteric
  • Formerly 'Mackem'
« Reply #457 on: Mon, 24 June 2013, 18:49:49 »
Need to try and sell my Filco cable since I don't use it anymore to buy a one for my Quick Fire Rapid!
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #458 on: Thu, 27 June 2013, 14:42:50 »
Little something from today.... 'Hornet Strike' (black and yellow) Paracord Extension cables... very happy with how these came out.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #459 on: Thu, 27 June 2013, 16:01:23 »
More sleeving with the new MATTE sleeving  :cool:
Offline Qipz
« Reply #460 on: Tue, 02 July 2013, 17:25:41 »
Hey Pexon, I heard you make some nice cables, I just ordered a GH60 and I was wondering, the cable that I'd need to use it would be a MINI USB B CABLE right?
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #461 on: Tue, 02 July 2013, 17:27:54 »
Thats the one dude! They are on my site www.pexonpcs.co.uk
Offline Qipz
« Reply #462 on: Tue, 02 July 2013, 17:39:17 »
Great! Ordering one as soon as I find a good case for my GH60 and I can pick the colour for my cable!
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #463 on: Tue, 02 July 2013, 17:42:05 »
OK dude, nice one, just let me know if you want anything fancy, so I can get it in for you.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #464 on: Mon, 08 July 2013, 15:28:49 »
Some audio cables from today. Lots more USB cables to make tomorrow.
« Reply #465 on: Wed, 10 July 2013, 16:59:27 »
What kind of sleeving is this? Looks much thicker than a lot of your other cables. I really like the look of it.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #466 on: Wed, 10 July 2013, 17:05:29 »
Its Blue Techflex, the cable is 3 core Silver plated OFC hence the thicker insulation. Techflex is pretty thin, not as good a weave as the matte sleeving I use or MDPC.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #467 on: Sat, 13 July 2013, 16:31:34 »
Audio cable from the other day....
www.pexonpcs.co.uk
Offline YongJK
« Reply #468 on: Tue, 16 July 2013, 04:23:24 »
Sigh. It has been more than 1 month I am still not receiving my mail.
For ordering next time, I wouldn't mind you to offer more expensive shipping with tracking.
Keyboard: PLU ML87 Mx Blue
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #469 on: Tue, 16 July 2013, 04:27:55 »
Send me a message mate, I will get some new ones sent out free of charge
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #470 on: Tue, 23 July 2013, 16:24:40 »
The Titanium Grey MPDC cable arrived save and sound. Thank you Pexon!
Pexon Cable - MDPC Titanium Grey by cpkey, on Flickr
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #471 on: Tue, 23 July 2013, 16:56:20 »
Awesome! Good one dude!  8)
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #472 on: Thu, 25 July 2013, 10:05:06 »
Just placed an order :D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #473 on: Thu, 25 July 2013, 15:10:59 »
Thanks dude!  ;D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #474 on: Mon, 12 August 2013, 15:23:24 »
Recently sleeved some PSU cables for a friend using nice and simple black and blue paracord. I'm very happy with the result. For reference, this job took about 6 hours and they are the Silverstone short PSU replacement cables....
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #475 on: Mon, 12 August 2013, 15:24:15 »
they look amazing sir, cant wait to get mine done
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #476 on: Mon, 12 August 2013, 15:41:38 »
Thanks Bunny!!!  :D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #477 on: Fri, 30 August 2013, 16:24:13 »
Some more potato pics
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #478 on: Fri, 30 August 2013, 22:06:36 »
Damn, your cables are now approaching the "PERFECTIONIST Level".  Love the quality fittings, like you'll find on the really expensive versions available through limited distribution channels.
Your new stuff looks fine with $20,000 sound gear  :thumb: .
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #479 on: Sat, 31 August 2013, 03:37:40 »
Thanks so much Elrick!  ;D
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #480 on: Tue, 03 September 2013, 12:11:13 »
Any chance you could do a right angle coiled mini-usb cable wrapped in paracord? :)
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #481 on: Tue, 03 September 2013, 12:39:32 »
That would be no issues at all brother! Send me a message and I will quote you up!  :thumb:
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #482 on: Tue, 03 September 2013, 12:55:52 »
Can do :D thanks a bunch!
TOO BAD FOR YOU
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #483 on: Fri, 13 September 2013, 17:22:47 »
Offline HesterDW
« Reply #484 on: Mon, 16 September 2013, 19:13:03 »
PM sent.
« Last Edit: Fri, 20 September 2013, 21:02:36 by HesterDW »
