Author Topic: Whitening keyboard body  (Read 3433 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Mon, 10 December 2012, 10:34:02 »
So I just bought a G80-3700 but the body and PS2 cords is a bit yellowed. What's the best way to clean it? Will retro-bright work on something like this (even the cord)?
Thanks ^____^
Offline SmallFry
Re: Whitening keyboard body
« Reply #1 on: Mon, 10 December 2012, 10:52:13 »
If I recall correctly, rubber decays quickly in Retr0brite...I think it may work, just be careful:)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Mon, 10 December 2012, 10:56:43 »
Dang, I guess if it comes down to it, I'll have to sleeve it.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Mon, 10 December 2012, 11:08:10 »
oxi clean, oxi-clean..........oxi-clean!
1/4 part to 1 gallon. i usually make 1 cup to 4 gallons of water and add about a cup of hydrogen peroxide
pour in something kind of flat, yet will handle the size of a keyboard, keycaps, etc.- heck you can form something and just use a big plastic trash bag as it will not leak.
the water should be deep enough to submerge, however everything will float on top.
* IMPORTANT- it must be set in "direct sunlight/uv"....... i usually set mine out for about 4-6 hours dunking in the oxi clean-water mix quite a few times.
i'm not a chemist, but the ox- clean/water - uv has REMOVED at least 70-90% of yellow from age, etc. restoring pretty the default color when the plastic was new. that would be the case and the keys!
it is not a gimmick, but actually works. i would not mix any stronger so as not to fade the legends.
hope this helps.......... :D
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Mon, 10 December 2012, 11:09:18 »
Do the body, don't bother with the cable. Surely people will have some spare cable left over from G81 harvesting.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Mon, 10 December 2012, 11:12:34 »
*Snip*
It sure does, thanks a ton
Could I use a G81 cable that is USB? Would that even work or would I need to find one that is also PS2?
« Reply #6 on: Mon, 10 December 2012, 11:13:30 »
ps/2 or at can replace direct. If want to use usb would have to controller replace.
