Author Topic: Are your lotus and japan keys bright white?  (Read 8151 times)
Offline nullstring
« on: Tue, 11 December 2012, 20:27:42 »
I know for a fact that your ying yang key is bright white:
Are these two keys the same white? I can't tell if the lighting is slightly different or if they are slightly grayer.
Thanks. :)
EDIT: now that I've posted them next to each other, I'm sure they are the same white.
However, if you wouldn't mind confirming real quick, I'd appreciate it :)
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
Re: Are your lotus and japan keys bright white?
« Reply #1 on: Tue, 11 December 2012, 20:38:47 »
The lotus and the japan are the same white but they are both slightly more off white than the yinyang
9734-0
Offline nullstring
« Reply #2 on: Tue, 11 December 2012, 20:40:46 »
Ah, dang. I was hoping for the same white.
Thanks for the fast response i3.
Offline Lu_e
« Reply #3 on: Wed, 12 December 2012, 13:48:13 »
How about the ghost key? is it NN black?
You may want to consider adding this information to your store. If not color codes, then at least a descriptor of the color would be ideal.
Just say NO to ABS keycaps
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #4 on: Wed, 12 December 2012, 14:34:13 »
Ghost key is NN
