Author Topic: Mechanical tenkeyless with fullsize enter mainly for programming tasks  (Read 3421 times)
Offline d00de
Hello,
I'm new here, but been reading a lot as a guest to get myself into mechanical keyboards a little better. I'm in a search for mechanical keyboard that will be used mainly for programming, stepping through the code and similar tasks.
I don't know exactly what model and switches should I get because I didn't have a chance to try MX switches before. I got one Cherry G81-8000 from a local ebay site but I found out that it's using lousy MY switches so I'm looking for a real thing now.
I would prefer a full size keys (Enter, ctrl, shift) and would like it to be a tenkeyless if it's possible. It should have regularly positioned arrow keys and home/end block. I can't buy mechanical keyboards in my country with localized key caps (instead of some steelseries perhaps) so I'll be ordering it online. If it's possible, I have some cherry key caps (compatible with mx switches) so I'd like to replace some of the original once that come with keyboard because my keyboard layout is not US.
Here is the layout that I like, but when i tried to get me one of Filco's tenkeyless models they all happened to be with small size enter caps.
http://www.keyboardco.com/keyboard_images/filco_tenkeyless_brown_uk_small.jpg
I also like the older Cherry G80 models but for the price of them I believe it's better to get me a Filco or something similar.
TIA for your suggestions,
Djud.
Offline daerid
    • Rossipedia
Re: Mechanical tenkeyless with fullsize enter mainly for programming tasks
« Reply #1 on: Wed, 12 December 2012, 03:40:05 »
In EU, your best bet is probably The Keyboard Company. Not sure if they have your exact layout, but it's worth a shot. Maybe one of these?
Offline vun
  • Just one more thing
« Reply #2 on: Wed, 12 December 2012, 04:40:32 »
I've bought 2 tenkeyless Filcos from KeyboardCo, both had the UK ISO you're looking for. You can also order a set of blank keycaps with the board and replace the keys that would be localized with blank ones or just go all blank.
Offline d00de
« Reply #3 on: Wed, 12 December 2012, 05:21:02 »
This is the one I'm thinking of buying:
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=1044
Which switches should I choose (brown or blue), the only difference that I know is the click sound which I think I'll like therefore I should go for blues?
Offline laffindude
« Reply #4 on: Wed, 12 December 2012, 07:54:10 »
Good thing I didn't post when I saw this thread. I assumed he meant that the ISO enter is too small, and he wanted the BIG ASS enter. Those are really hard to find.
« Reply #5 on: Wed, 12 December 2012, 08:05:28 »
The tactility is sharper on the blues. If you don't mind the sound, then I would suggest them.
