Author Topic: The Toxic set [restructuring with ctrl alt store]  (Read 616514 times)
Offline Full_Battle_Rattle
Re: The Toxic set [taking orders](Waiting on Cherry replica set)
« Reply #1000 on: Fri, 24 May 2013, 22:22:42 »
I can't wait. This will be my first group buy!
Offline Badwrench
  • ummmm.....I forgot
« Reply #1001 on: Sat, 25 May 2013, 01:22:08 »
I need to add the tsangan set in toxic to my order.  Did you get my pm about removing the numpad set?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1002 on: Sat, 25 May 2013, 02:53:25 »
Daniel is on Honeymoon! He won't be back till the 5th or 6th.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1003 on: Sat, 25 May 2013, 02:54:26 »
AWWWW YEEEAAAAH
Offline stoic-lemon
« Reply #1004 on: Sat, 25 May 2013, 02:55:53 »
Gonna put in my order just before the deadline. This delay has worked out very well for me.
« Reply #1005 on: Sat, 25 May 2013, 04:23:58 »
Welcome to Geekhack!
Brace yourself - it is unlikely to be your last ;)
Offline bianco
« Reply #1006 on: Sat, 25 May 2013, 07:23:36 »
looks nice!
submitted my order
hope i can still join in
Plenty of time - still taking orders :)
thanks! first time to participate in a group buy here.
looking forward to more
Offline Badwrench
« Reply #1007 on: Sat, 25 May 2013, 10:50:19 »
Nice!  Hope he has a good time.
Offline lewi
« Reply #1008 on: Sat, 25 May 2013, 20:18:21 »
im, in
« Reply #1009 on: Sat, 25 May 2013, 22:44:34 »
Thanks! I got a blue switch Pure from MK on a recommendation from a co-worker. Then I found techkeys and got a bunch of stuff there. Theeennn there was keypop. Now I need to go to keycap addict meetings or something.  :D
Offline PandaSPUR
« Reply #1010 on: Sat, 25 May 2013, 22:52:33 »
Whens the deadline? :o
I'll be getting my KBT Pure in the mail on Tuesday, so I was hoping to wait until then to place my order here.
Question, do I need any of the extra space bars for that keyboard?
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1011 on: Sun, 26 May 2013, 00:30:43 »
There's no real set deadline, only that Dan will start accepting payments when the first Cherry replica sets are done, and that's a long ways away, I think; you should be fine if you're going to order by next week.
You will not need the extra spacebars for the KBT Pure.
Offline bench
« Reply #1012 on: Sun, 26 May 2013, 08:38:07 »
Which sets do I need for a Qpad mk50?
-base
-Num
-ISO mods
-Which spacebar..?
Thanks for your help!
Offline longweight
  • philanthropist
« Reply #1013 on: Sun, 26 May 2013, 09:15:56 »
There must be another price break on the base set...
Offline Tym
« Reply #1014 on: Sun, 26 May 2013, 09:20:08 »
I believe someone said it was at 500.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #1015 on: Sun, 26 May 2013, 09:35:10 »
Any chance we can get a link to the Cherry Replica set thread in the OP so that newcomers to this thread can check on the status of that buy?
Offline xpistalpetex
« Reply #1016 on: Mon, 27 May 2013, 00:41:34 »
-base
-Num
-ISO mods
-Which spacebar..?
someone with more experience please correct me.
It seems base kit and iso kit would work but i think the space bar is a 6.0
Offline LechnerDE
« Reply #1017 on: Mon, 27 May 2013, 00:44:35 »
-base
-Num
-ISO mods
-Which spacebar..?
Indeed.
The spacebar has an uncommon format and different stem positions so you'd have to keep it which sucks, because it has a different profile than the Toxic Set...
Offline bench
« Reply #1018 on: Mon, 27 May 2013, 03:01:05 »
Thank you, that's what I was afraid of...
I wanted to replace that because of the big fat Q on it.
Is there a place where I can get a blank 6.0 with fitting mounts from?
Ta!
bench
Offline LechnerDE
« Reply #1019 on: Mon, 27 May 2013, 03:08:40 »
Ta!
bench
Never heard of such a spacebar.
The only chance I see to replace it, is using 1x Alt keys and try to mod a 7x spacebar to fit the Qpad board.
But I guess that won't look too pretty either ;)
Offline mauri
« Reply #1020 on: Mon, 27 May 2013, 03:21:25 »
Ta!
bench
Can't say for sure what mounts the qpad has but some old cherries have 6x spacebar, for example G80-1800, I've found them for 10-20€ from ebay but you'll have to check the fitting yourself
I AM BABAR KING OF THE ELEPHANTS
Offline longweight
  • philanthropist
« Reply #1021 on: Mon, 27 May 2013, 04:42:33 »
hmmm.
Offline JFroese
« Reply #1022 on: Mon, 27 May 2013, 21:39:10 »
Hi, I just ordered the Base Kit but I also wanted the Modifier Kit but forgot to select it. Is there any way someone can just add it on to my order? Sorry, I'm new to this, trying it out after a friend recommended group buying.
Offline Potologue
« Reply #1023 on: Tue, 28 May 2013, 08:03:31 »
Send a pm to the person running the gb.
« Reply #1024 on: Tue, 28 May 2013, 17:20:28 »
Someone said "Daniel is on Honeymoon! He won't be back till the 5th or 6th." so PM, but don't expect an immediate reply.
Still a little while to go on these, so don't panic.
Offline PandaSPUR
« Reply #1025 on: Tue, 28 May 2013, 18:49:41 »
Just added my order :D
Home:
Work:
Offline Plater
« Reply #1026 on: Wed, 29 May 2013, 01:50:33 »
Glad to have submitted my order!
Offline promptcurry
« Reply #1027 on: Wed, 29 May 2013, 15:40:05 »
Is there any ETA as to when the Cherry Replica set will be finished?
« Reply #1028 on: Wed, 29 May 2013, 15:46:58 »
you can check on that over in the cherry replica thread
http://geekhack.org/index.php?topic=42659.0
also hopefully the OP can be updated with all the recent orders....when daniel gets back to the real world  :p
« Last Edit: Thu, 30 May 2013, 07:47:50 by ray4jc »
Offline keyit
« Reply #1029 on: Fri, 31 May 2013, 04:55:27 »
Order added!  :D
boop
Offline jonnybastard
« Reply #1030 on: Mon, 03 June 2013, 06:48:59 »
Just put in an order, don't know why I didn't sooner haha
KMAC    -    HHKB Type-S    -    Filco TKL LineaR    -    Poker X    -    KBT Race LE
flickr
Offline Moomoo
« Reply #1031 on: Tue, 04 June 2013, 03:31:24 »
You watch this is going to turn out just like the Raindrop set, once it's closed people are going to go ballistic
Offline okooko
  • afk.
« Reply #1032 on: Tue, 04 June 2013, 03:33:45 »
pretty sure this will be nothing like the raindrops gb, its been how long since this thread has been up?
i filled the form a long time before rumours of the lzgh came up and ill most likely get my assembled lzgh before this gb closes
Offline Moomoo
« Reply #1033 on: Tue, 04 June 2013, 03:34:40 »
mang why you ruining my parade
Offline bench
« Reply #1034 on: Tue, 04 June 2013, 05:26:09 »
What was it with the rainbow set?
« Reply #1035 on: Tue, 04 June 2013, 07:21:30 »
It was raindrop and what they are referring to is the inevitable condition that happens once a group buy is done that suddenly everyone realizes they have missed and out beg, borrow, plead and steal to get back in.
But hopefully everyone will go ahead and order and this will turn out to be a very large and very successful group buy!!
Offline hbdongdg
« Reply #1036 on: Tue, 04 June 2013, 19:16:30 »
May I order now ?
Offline Rayne
  • For Science!
« Reply #1037 on: Tue, 04 June 2013, 19:55:22 »
May I order now ?
still says [taking orders] in the title, so yes.
Just read the OP
Offline okooko
  • afk.
« Reply #1038 on: Tue, 04 June 2013, 21:02:06 »
every gb you see, just order 2 bases, 2 mods 2 tsangans. standard order right there.
Offline Badwrench
« Reply #1039 on: Mon, 10 June 2013, 12:49:42 »
I wish.  I had to look and consider which gb to get in on based on the colorway that I really wanted and go with that - ended up with this one.  Unfortunately, the timing on this one has been stretched considerably, but still should be worth the wait.  It's been going so long, that my order has grown significantly, but still not the double double setup  :-[
Offline halllo
« Reply #1040 on: Wed, 12 June 2013, 05:04:20 »
hi..hv a question wanna ask ..about the toxic modifiers Kit come with space bar?
it's state 34 keys but i count there's only 33 keys..???
Offline GeeNDL82
« Reply #1041 on: Wed, 12 June 2013, 05:36:16 »
I hope this GB will be collected cash soon. Cannot wait to own one set :D
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
Offline Winther
« Reply #1042 on: Sat, 15 June 2013, 21:08:58 »
Anyone know where danielucf is?
I would like to cancel my order but he does now reply..
Offline MKULTRA
  • telling it how it is
« Reply #1043 on: Sat, 15 June 2013, 23:23:33 »
He is a verrrry busy man at the moment.
Offline phx
« Reply #1044 on: Sun, 16 June 2013, 00:25:34 »
o damn I forgot I was in this GB...
this is taking forever  :blank:
Offline MKULTRA
« Reply #1045 on: Sun, 16 June 2013, 00:40:20 »
Waiting for cherry legends.  Will be worth the wait.
Offline jingil
« Reply #1046 on: Sun, 16 June 2013, 00:49:04 »
May I order now? Form filled.
DUCK MINI V1 ll 356MINI
Offline phx
« Reply #1047 on: Sun, 16 June 2013, 00:55:10 »
dont think I'll notice the difference.
Offline MKULTRA
« Reply #1048 on: Sun, 16 June 2013, 01:08:34 »
I'm almost positive you will
vs
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #1049 on: Sun, 16 June 2013, 06:04:00 »
From those comparison pics it's a no brainer for me, Cherry legends or nothing!
