Author Topic: Zenith Data Systems Keyboard: dead?  (Read 3190 times)
Offline Barbastruzzolo
  • No money to buy a Topre
« on: Fri, 14 December 2012, 10:08:14 »
Recently I received as gift a beautiful  Zenith Data Systems Keyboard whit green ALPS like this: http://www.ebay.com/itm/Vintage-Zenith-Data-Systems-Keyboard-Z-Series-Z-151-/160910170140?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D4151442356190693011%26pid%3D100011%26prg%3D1005%26rk%3D3%26sd%3D160901070530%26
I connected it to my PC using a AT/XT to PS2 converter and... nothing appened! It doesn't work.
The only life sign is a firm RED  led on the Num Lock button and nothing else :-(
I cleaned the keyboard using a brush and a deoxidizer spray for electronic circuits but the problem remains.
What should I do to get it work again? It feels very very nice at tact and I don't want to throw it away
Filco FKBN88M/UKB2 || Cherry G80-3000LSCIT-2 || Cherry G80-3000 LPCEU-2 || Apple Extended Keyboard II (QZERTY) || Filco MINILA FFKB68MRL/UKB
Offline JPG
  • Model F is my new passion!
Re: Zenith Data Systems Keyboard: dead?
« Reply #1 on: Fri, 14 December 2012, 10:37:22 »
Did you reboot your computer after plugging the keyboard?
Offline laffindude
« Reply #2 on: Fri, 14 December 2012, 10:44:06 »
Is it an XT board? You need to use an active converter to use that on a PS2 port.
Offline scoot
« Reply #3 on: Fri, 14 December 2012, 10:45:21 »
PS2 isn't hot-pluggable. Shut your computer down, plug the keyboard in while the computer is off, then boot your computer back up. Hopefully that fixes it for you!
« Reply #4 on: Fri, 14 December 2012, 11:41:42 »
I shutdown my computer before plugging in the keyboard connector.
I can't exactly tell if  it's AT or XT (the keyboard has no labels outside nor inside).
For active converter do you mean something like http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11298/subcatid/0/id/500722 ?
Offline laffindude
« Reply #5 on: Fri, 14 December 2012, 11:55:14 »
One of those will work. Though, if you don't absolutely need PS2, there is this.
Offline SmallFry
« Reply #6 on: Fri, 14 December 2012, 17:51:08 »
That is an XT board... I fried mine that way...
« Reply #7 on: Sat, 15 December 2012, 01:38:43 »
Can you be more precise? What appened?
Offline SmallFry
« Reply #8 on: Sat, 15 December 2012, 04:20:38 »
Not quite sure, but I do know that I fried mine...:(
