Author Topic: [IC] Phantom PCB  (Read 81114 times)
Re: [IC] Phantom PCB
« Reply #50 on: Fri, 14 December 2012, 14:26:45 »
lol why is there even an interest check for this? gogogo!!!
Offline bavman
« Reply #51 on: Fri, 14 December 2012, 14:31:18 »
We need to get pricing and all that good stuff figured out before an official gb goes up
Offline Leewei
« Reply #52 on: Fri, 14 December 2012, 14:33:39 »
Interested. GOGO!
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline SmallFry
« Reply #53 on: Fri, 14 December 2012, 14:42:35 »
I say we add plates to this buy as well as SET cut off dates as to not let this go on longer than necessary, but I'm not participating, so good luck to you all!
Offline aggiejy
« Reply #54 on: Fri, 14 December 2012, 16:42:12 »
1+ for adding plates
Offline akuJIWA
  • Lock 'N Load!
« Reply #55 on: Fri, 14 December 2012, 22:57:10 »
+1 plates as well, I'm in either way.
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #56 on: Fri, 14 December 2012, 23:08:27 »
In for +1 PCB =)
Offline ekw808
  • Ekw
« Reply #57 on: Fri, 14 December 2012, 23:35:10 »
+1
[One Keyboard at a time]
Offline daerid
    • Rossipedia
« Reply #58 on: Fri, 14 December 2012, 23:41:35 »
Aside from the WASD V2, this is the only thing that'd make me buy more Cherry switches. Consider me in (for AT LEAST one, probably two).
Offline WhiteFireDragon
    • youtube
« Reply #59 on: Sat, 15 December 2012, 02:15:42 »
Because this is one of the more interesting TKL keyboards. It'll be superior to the Korean customs if we can get an aluminum metal case with it.
    • youtube
« Reply #60 on: Sat, 15 December 2012, 02:24:29 »
Btw I got a few PMs for questions of total costs and help with assembly. I'll just post it here too so know you what parts to source and cost expectations:
  • 1 PCB $35
  • 1 case $??
  • 1 plate $18
  • 1 teensy controller $20
  • 87 diodes $2
  • 87 switches ~$60
  • 10 stabilizers (plate mounted cherry or costar) ~$10
  • 1 USB cable $??
  • keycaps $??
That's roughly $150 before shipping and other fees. Of course the number of switches and diodes will vary depending on the layout you choose, but not by much. The only layout that adds significant amount of switches is the 7bit layout, which is a little over 100 switches.
edit: I just realized tjcaustin also posted a list of things needed. It's correct for the most part but $300 is grossly overestimated unless that includes buying a brand new $150 filco just for the case.
« Last Edit: Sat, 15 December 2012, 02:37:27 by WhiteFireDragon »
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #61 on: Sat, 15 December 2012, 02:39:36 »
+1
Offline akuJIWA
  • Lock 'N Load!
« Reply #62 on: Sat, 15 December 2012, 02:49:39 »
  • 1 PCB $35
  • 1 case $??
  • 1 plate $18
  • 87 diodes $2
  • 87 switches ~$60
  • 1 USB cable $??
  • keycaps $??
Thank you, WFD. Can I PM you for some questions after getting the PCB? I really want to learn how to assemble it myself, otherwise can you set it up?
quit
Offline pmh1410
« Reply #63 on: Sat, 15 December 2012, 03:08:06 »
i'm in for one  :)
« Last Edit: Sat, 15 December 2012, 09:35:15 by pmh1410 »
    • youtube
« Reply #64 on: Sat, 15 December 2012, 03:09:36 »
You can PM me questions but just post it in the main thread so everyone else can benefit from question/answer too. I urge people to assemble or mod their own keyboards, that's why I made THIS video. I also have a video of a phantom assembly process from start to finish but been too lazy to edit and upload the video. I'll upload that specific video when we get closer to the GB.
Offline akuJIWA
  • Lock 'N Load!
« Reply #65 on: Sat, 15 December 2012, 03:14:05 »
Thanks a lot, sir.
quit
Offline Sai
« Reply #66 on: Sat, 15 December 2012, 03:21:59 »
Please post the video. that way i can do by myself. !! :D
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: [IC] Phantom PCB
« Reply #67 on: Sat, 15 December 2012, 03:25:10 »
there was a good diy thread origiannly for the phantom that was more than good enough to figure out how to build it idk if its still available on gh might want to try DT.
Offline Sai
« Reply #68 on: Sat, 15 December 2012, 03:32:26 »
now that you mentioned it, i remember seeing it when i was searching for Phantom.
Offline Batmann
« Reply #69 on: Sat, 15 December 2012, 03:37:19 »
That's the spirit, DIY is the way to go =)
In for 1 PCB at least
few questions though:
- to WFD: your plate will fit the PCB rigth?
- not sure about that but will the pcb fit in the vortex tkl alu case?
Treble cases look superior to everything I've seen so far, It would be great to work something out with him (like a killer alu case signed with a phantom logo a la LZ cases)
« Reply #70 on: Sat, 15 December 2012, 04:03:31 »
No it wont fit in a Vortax Alu Filco case as the plates edges need to be bent.
« Reply #71 on: Sat, 15 December 2012, 04:04:47 »
Also http://geekhack.org/index.php?topic=38305.0 for assembly services if you need them.
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #72 on: Sat, 15 December 2012, 04:05:26 »
Broken link, my friend :D
And it fits into a regular Filco TKL casing?
« Reply #73 on: Sat, 15 December 2012, 04:07:07 »
sorry i think since its an interest check it has to be authoized first or what ever sorry will repost when its working.
Also yes fit a Filco TKL or PLU-87.
Offline Shadovved
« Reply #74 on: Sat, 15 December 2012, 04:08:25 »
I see.....
Then I would need a new case........  :( :(
« Reply #75 on: Sat, 15 December 2012, 04:11:35 »
I see.....
get a plu then and use the case and switches?
Offline Shadovved
« Reply #76 on: Sat, 15 December 2012, 04:18:01 »
I see.....
Imma lusting for something custom made  ;D ;D
DIY in SS, I only lack the schematics  ;) ;)
Re: Re: Re: [IC] Phantom PCB
« Reply #77 on: Sat, 15 December 2012, 04:19:05 »
I see.....
i want stainless case too but that may have to wait for phantom v2 as it seems everyone waht to push this buy along.
Offline Shadovved
« Reply #78 on: Sat, 15 December 2012, 04:22:05 »
I see.....
I might wanna do it myself I think.... but I am reluctant to pick apart my Filco LOL ;D ;D
Wondering if anyone has already done that and has the blueprints?????
Offline akuJIWA
  • Lock 'N Load!
« Reply #79 on: Sat, 15 December 2012, 04:22:38 »
Does it fit into a QFR case?
quit
Offline dirge
« Reply #80 on: Sat, 15 December 2012, 04:36:43 »
phantom gb 2 needs to have a heavy focus on a case.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline Shadovved
« Reply #81 on: Sat, 15 December 2012, 05:34:26 »
CASING FTW!
Offline gameaholic
« Reply #82 on: Sat, 15 December 2012, 05:55:29 »
in
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #83 on: Sat, 15 December 2012, 06:16:55 »
in for one
Offline Donbabbeo
« Reply #84 on: Sat, 15 December 2012, 06:37:07 »
in for at least one, maybe two
Offline netdevil
« Reply #85 on: Sat, 15 December 2012, 06:53:18 »
Dam another blow to the the wallet  :-\ Interested!
« Last Edit: Sat, 15 December 2012, 08:07:18 by netdevil »
Offline pasph
« Reply #86 on: Sat, 15 December 2012, 08:43:38 »
please make also a PHISO125 plate.
It will fit in the MKC alu cases?
Offline Shadovved
« Reply #87 on: Sat, 15 December 2012, 08:44:48 »
As reported by others, no-go with the MKC casing  :p :p
Offline pasph
« Reply #88 on: Sat, 15 December 2012, 09:06:06 »
so i wish finally someone make a good tkl alu case!
    • youtube
« Reply #89 on: Sat, 15 December 2012, 09:26:49 »
Vortex has one for cheaper, but you'll just have to use the stock filco plate with it. Also the quality is not so great.
« Reply #90 on: Sat, 15 December 2012, 09:27:04 »
Cross posted this IC to Deskthority here: http://deskthority.net/marketplace-f11/phantom-pcb-t4646.html
    • youtube
« Reply #91 on: Sat, 15 December 2012, 09:31:52 »
Yeah it was made to fit phantom PCB also. In one of the pics in my GB, the plate was mounted on a phantom PCB and installed in a filco case, everything lines up well:
The PCB might work inside the vortex aluminum case, but I wouldn't count on it because it needs to be paired with a stock Filco or CM quickfire plate. Any plates that are just flat without the top and bottom bends will not work.
« Reply #92 on: Sat, 15 December 2012, 09:48:46 »
no as the standoffs are in different places.
« Reply #93 on: Sat, 15 December 2012, 09:52:46 »
Well my thread got authorized so if your looking for assembly services please take a look at this thread http://geekhack.org/index.php?topic=38305.0
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #94 on: Sat, 15 December 2012, 10:33:04 »
  • 1 PCB $35
  • 1 case $??
  • 1 plate $18
  • 87 diodes $2
  • 87 switches ~$60
  • 1 USB cable $??
  • keycaps $??
Or planning to spend that much on a one off aluminum case/risking a vortex aluminum one.  Besides, I would rather plan to have more money than needed than not enough.
Offline daerid
    • Rossipedia
« Reply #95 on: Sat, 15 December 2012, 12:19:55 »
In for a plate or two as well.
Offline metafour
« Reply #96 on: Sat, 15 December 2012, 13:04:22 »
I'm in for at least one if not two PCBs
Offline TheQsanity
  • SmallFry Lovin'
« Reply #97 on: Sat, 15 December 2012, 20:08:53 »
Yea, I'm in I just have to check out the past forum stuff on how to put it together ><.
SmallFry! <3
Offline clakdale661
« Reply #98 on: Sun, 16 December 2012, 12:11:00 »
I heard about this "Phantom" keyboard and very interested in it. But the cost in switches alone is almost the cost of a complete keyboard (like the CoolerMaster Quickfire TKL). I need to start budgeting for this, so is there a ETA for when these will get released?
« Reply #99 on: Sun, 16 December 2012, 21:04:11 »
I'm in for one to pair with the extra phantom plate I got.
