Author Topic: spray painting my keyboard  (Read 4040 times)
Offline hluo87
« on: Fri, 14 December 2012, 15:54:44 »
hi all
i plan to spray paint my CM RQF this weekend...i need some advice choosing the right spray
some ppl says using  Krylon Fusion
should i also get primer + clear????
some ppl says just go with Dupli-Color High Performance Vinyl and Fabric Spray
http://www.amazon.com/Dupli-Color-HVP102-Performance-Vinyl-Fabric/dp/B0007U94T6/ref=sr_1_9?ie=UTF8&qid=1355521921&sr=8-9&keywords=vinyl+car+spray
what i should get :-X
the following links are reference...
http://geekhack.org/index.php?topic=37537.msg716490#msg716490
http://geekhack.org/index.php?topic=30620
http://www.overclock.net/t/1314293/changing-keyboard-casing-color/10
Offline cytoSiN
  • ATCG
Re: spray painting my keyboard
« Reply #1 on: Fri, 14 December 2012, 16:02:22 »
Is the badging on yours raised, or is smooth/flush with the case?  Might want to sand first if it's raised.  Interested to see how this turns out.
Model M 1391401 1989 || Ducky DK9008G2 Pro LE || XArmor U9BL-S LED || CM Storm QuickFire Rapid
Offline hluo87
« Reply #2 on: Fri, 14 December 2012, 17:40:30 »
i just dont like the logo...
want to get rid of it-_-
lol
Offline Firefly303
« Reply #3 on: Sat, 29 December 2012, 20:58:13 »
Having the same problem. not sure if i should go with Vinyl dye, rust-oleum, or Krylon fusion :/
Offline cytoSiN
  • ATCG
« Reply #4 on: Sat, 29 December 2012, 22:16:08 »
I plan to paint my sanded QFR with this: http://www.rustoleum.com/CBGProduct.asp?pid=178
I think it's the same one metalliqaz used on his Filco, which looks great imo:  http://geekhack.org/index.php?topic=38404.0
« Reply #5 on: Sun, 30 December 2012, 00:41:18 »
I think what you go with should depend somewhat on how much effort you want to put in.  I didn't want to expend too much time, so I went with an all-in-one.
Offline cytoSiN
  • ATCG
« Reply #6 on: Sun, 30 December 2012, 08:04:05 »
And you still spent more than a week with several coats :D
« Reply #7 on: Sun, 30 December 2012, 08:12:57 »
Well it definitely sat there for more than a week, but the painting was all one afternoon.
Offline cytoSiN
  • ATCG
« Reply #8 on: Sun, 30 December 2012, 12:49:54 »
Either way, yours came out looking very nice and smooth with that paint.  Do you have any reservations about using it?  Would you use something else if you were to do it again?
