Author Topic: capacitive?  (Read 5211 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
capacitive?
« on: Fri, 24 August 2007, 01:09:37 »
What kind of mechanism is that and what uses it?
Never heard of it.
Offline iMav
  • geekhack creator/founder
Re: capacitive?
« Reply #1 on: Fri, 24 August 2007, 02:09:33 »
Quote from: xsphat
Never heard of it.
From wikipedia:
Capacitive keyboard
In this type of keyboard, pressing the key changes the capacitance of a pattern printed on a PC board. Usually this permits a pulse or pulse train to be sensed. Unlike "dome switch" keyboards, the pattern will be covered by a thin, insulating film. Capacitive keyboards are inexpensive, and resist wear, water, foreign objects and dirt. They are common in PC keyboards.
This type of keyboard uses changes in capacitance (stored static electricity), rather than changes in flows of electricity to register a keystroke.
The HHKB Professional uses capacitive keyswitches coupled with cone-shaped spring.  See here.
Offline xsphat
  • Enlightened
capacitive?
« Reply #2 on: Fri, 24 August 2007, 02:27:21 »
Impressive, thanks.
Offline xsphat
  • Enlightened
capacitive?
« Reply #3 on: Fri, 24 August 2007, 02:39:34 »
So do the newer Microsoft and (C)apple mushy style keyboards use this?
Offline iMav
capacitive?
« Reply #4 on: Fri, 24 August 2007, 02:45:25 »
Quote from: xsphat
I believe they use membrane switches (see the above link and look at what the HHKB Lite keyboard uses).
I am most-certainly not an expert though.  If you turn up different information, let me know.  :)
Offline xsphat
  • Enlightened
capacitive?
« Reply #5 on: Fri, 24 August 2007, 02:47:14 »
will do
Re: capacitive?
« Reply #6 on: Wed, 01 April 2015, 17:48:13 »
Did you ever find more information?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: capacitive?
« Reply #7 on: Wed, 01 April 2015, 17:49:51 »
Re: capacitive?
« Reply #8 on: Wed, 01 April 2015, 18:25:49 »
OP never updated, the suspense is killing me.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: capacitive?
« Reply #9 on: Wed, 01 April 2015, 18:28:10 »
Yea same here.
I'm literally pissing myself in suspense.
Offline jonathanyu
Re: capacitive?
« Reply #10 on: Wed, 01 April 2015, 18:52:03 »
Offline Huxley2500
Re: capacitive?
« Reply #11 on: Wed, 01 April 2015, 21:02:51 »
2007 must have been a good year for keyboards.   :))
