Author Topic: [Orders Closed] Phantom PCB R2  (Read 361225 times)
Offline Piehunter
Re: [Orders Closed] Phantom PCB R2
« Reply #1250 on: Fri, 07 February 2014, 08:08:56 »
so umm... I was just wondering if all canadian orders were sent out or did mine just got lost in the mail...
Offline Dasuchin
« Reply #1251 on: Wed, 02 April 2014, 17:02:21 »
Is there another group buy for this or another way to get a PCB? I'm guessing this is the same thing thats listed here http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=536 ?
Offline duq
  • Connoisseur
« Reply #1252 on: Wed, 02 April 2014, 19:20:26 »
Essentially yes. This order came with some of the other things you would need as well. But the PCB should be identical... albeit white in color.
Offline boxfulofsanity
« Reply #1253 on: Thu, 17 April 2014, 09:23:53 »
Will another GB happen for the Phantom?
« Reply #1255 on: Thu, 17 April 2014, 09:25:58 »
No need. You can buy the PCB directly from mechanicalkeyboards.com
EDIT: Ninja'd by nubs.
Offline Wildcard
  • When caffeine isn't enough
« Reply #1256 on: Thu, 17 April 2014, 13:35:33 »
I have some extra stuff I might end up not using. Keep your eyes out in the classified section.
