Author Topic: Cherry profile vs Lower profile spacebar  (Read 3954 times)
Offline LollyWater
« on: Fri, 28 December 2012, 20:09:37 »
Is the spacebar effected in the height of lower profile and Cherry profile keycaps?
Offline Vintage
Re: Cherry profile vs Lower profile spacebar
« Reply #1 on: Fri, 28 December 2012, 20:50:02 »
Yeah, from what I know each profile has its own spacebar. Lower profile set = lower profile sapcebar in general
That is why many people prefer the Cherry Spacebar as oppossed to the SP spacebar which is said to be "sharp". I have only used OEM so far though, that is just what seems to be true based on what i've heard.
CM QFR w/ MX Reds  | Logitech G900
Offline jeroplane
« Reply #2 on: Sat, 29 December 2012, 00:21:23 »
SP space bars are like razor blades. But I use them anyway like a manly man.
My signature hasn't changed since 2012. I should really update it.
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #3 on: Sat, 29 December 2012, 00:41:00 »
you'll need to mod a cherry spacebar to fit it on a modern board, unless you're going winkeyless/7x.
personally i use a stock filco spacebar with my cherry doubleshots / dye subs, since i'm a lazy cretin and haven't modded the other one yet.  i'm pretty sure i would enjoy the cherry space bar a whole lot more, though.
« Last Edit: Sat, 29 December 2012, 00:42:40 by precarious »
Offline Tranquilite
« Reply #4 on: Wed, 02 January 2013, 01:34:29 »
I've used an SP spacebar for a long time now, and I don't get why people think they are sharp. I even type in such a way that I usually only hit the edge of the space-bar and it just doesn't seem all that sharp to me...
I guess I am just strange.
Offline precarious
« Reply #5 on: Wed, 02 January 2013, 01:41:57 »
are you using the legs on your keyboard?  the SP spacebars are more or less designed for that, otherwise the angle is horrible.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #6 on: Tue, 29 January 2013, 17:41:30 »
I just bought my first set of SP profile keys and I'm very disappointed in the spacebar. I didn't know what to call it, but hearing people refer to it as "sharp" is I think spot on.
I have a KBT Pure, so I suppose it's using the OEM profile, and I was really looking forward to the CCnG set I bought, but this spacebar is just awful.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Tue, 29 January 2013, 17:44:32 »
Try turning your SP spacebar up side down so that the razor side is to the back
