Author Topic: Center stem modding  (Read 2844 times)
Offline vun
  • Just one more thing
Center stem modding
« on: Sun, 30 December 2012, 14:46:00 »
So, I have a WYSE board that I can't use with anything so I'm trying to at least make use of the keycaps. The caps lock stem is off-center and I've heard it's possible to mod it so the stem is in the center, due to my lack of modding experience I don't want to dive into this so I'm wondering if anyone here knows a good way of centering the stem.
Re: Center stem modding
« Reply #1 on: Sun, 30 December 2012, 19:05:50 »
Not the easiest mod to start with.
You will need to cut the stem off cleanly, or get a donor stem from somewhere else. I would use a donor base, too. I kept various parts from several junk boards for projects like these.
The stem can be adhered with epoxy, and you will do well to make a jig out of wood in order to position it correctly. It would be almost essential that you have a proper example to build the jig around, then remove the original and set the new piece into the same setting.
I would set the naked stem in place, apply the wet epoxy, and carefully set the top exactly where you want it.
Perhaps someone else has a better idea.
« Last Edit: Sun, 30 December 2012, 19:10:35 by fohat.digs »
- D Trump 2026-10-24
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #2 on: Sun, 30 December 2012, 19:14:28 »
Any suggestions for an ideal epoxy to use for this application?  Or more specifically, for some hot ABS on ABS action?  That's the one thing, aside from a substantial amount of laziness, which is keeping me from doing the same with my Cherry stepped caps locks and space bars.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #3 on: Sun, 30 December 2012, 19:19:01 »
This is the link I sent to vun over IRC
http://imgur.com/a/3mWPe
KEYBOARD SCIENCE!!!
