Author Topic: List of Tenkeyless & Compact Keyboards  (Read 24505 times)
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: List of Tenkeyless & Compact Keyboards
« Reply #50 on: Thu, 04 April 2013, 15:13:43 »
There is also a Leopold FC200RE/AB which has MX Clear switches.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Tarzan
  • formerly known as Greystoke
« Reply #51 on: Thu, 04 April 2013, 15:20:10 »
Is there a sub-set of these TKL (or space-saver) keyboards that have Alps switches?
Filco Zero
Thanks!  I've also found links to the Ducky DK1087XM, not quite a TKL, but at least a smaller form factor.
By the way, are you located in the Czech Republic?  Just curious, saw the tag in your profile.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #52 on: Thu, 04 April 2013, 15:32:36 »
Under IBM, the M SSK should be called the "IBM Space Saving Keyboard".
There's also the M4 and its variants.
The later r/d versions with trackpoints are the "IBM Space Saver" (blue enter key and IBM logo on right as top edge is notched on left),  and the "IBM Space Saver II" (all black keys with IBM logo on left).
As well as the "external thinkpad keyboard", the UltraNav (there are a few variations of those too).
« Last Edit: Thu, 04 April 2013, 17:48:25 by E TwentyNine »
Offline gnubag
« Reply #53 on: Thu, 04 April 2013, 15:46:56 »
Filco Zero
The ducky DK1087XM is a TKL ...
Offline Tarzan
« Reply #54 on: Thu, 04 April 2013, 15:56:21 »
Filco Zero
Quite right!   :))
I was reading all the discussion about "tenkeyless" versus "space-saver" and I lost track of which board is called what.  What I was trying to say is that the Ducky XM is a small form factor, just not quite as small as something like the Noppoo Choc Mini.
I'm going to go back to obsessively packaging keycaps now.  I haven't had so many little bags of expensive stuff on my desk since my college days...   :-X
Offline davkol
  •  Post Editing Timeout
« Reply #55 on: Thu, 04 April 2013, 17:38:05 »
Filco Zero
Build quality of this ducky is supposedly... not ideal?
Yes, I am.
Offline gnubag
« Reply #56 on: Thu, 04 April 2013, 17:43:42 »
Filco Zero
its just the case construction from the lower price models, the shines and limited editions are pretty solid.
Offline davkol
« Reply #57 on: Fri, 05 April 2013, 05:51:57 »
Filco Zero
Yep... that comment was about Ducky DK1087XM though.
