Author Topic: What kind of Switches in a Focus FK-6000?  (Read 4822 times)
Offline M0rph3us
« on: Thu, 03 January 2013, 21:02:17 »
I recently came upon a Focus Electronics FK-6000 for extremely cheap. Now on to my questions. What switches does this thing have and does anyone know if the keys are removable on it? I have searched google, but I have found nothing about this keyboard even existing. It has a DIN adapter so I know it must be quite old and I would like to rehab it if possible. Judging by the other Focus boards I have found online I think it would have some kind of ALPS switches.
Thanks
Offline jabar
Re: What kind of Switches in a Focus FK-6000?
« Reply #1 on: Thu, 03 January 2013, 21:06:53 »
Other Focus varieties (2001, 5001) seem to have white ALPS switches.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline tipo33
  • "Ski"
« Reply #2 on: Thu, 03 January 2013, 22:11:36 »
More likely than not - white complicated, clicky ALPS
KM4COL    R.I.P.  SmallFry
Offline Hak Foo
  • Make America Clicky Again!
« Reply #3 on: Thu, 03 January 2013, 22:22:49 »
Some later ones (the 9200 with trackball) have rubber dome+slider, but the caps are sometimes still double-shot and ALPS compatible.
Overton130, Box Pale Blues.
Offline jabar
« Reply #4 on: Thu, 03 January 2013, 22:59:44 »
According to this article: http://kbtalking.cool3c.com/article/8366
the FK-6000 is some sort of ALPS knockoff which the article calls a mantis-foot system (F4 on that chart). The Deskthority wiki says it could be a clone of the XM simplified ALPS switch http://deskthority.net/wiki/XM
Phantom 7bit
Offline M0rph3us
« Reply #5 on: Fri, 04 January 2013, 03:25:45 »
Thanks for all the info guys!
How do I remove keycaps on these switches? If that is even possible. I really don't want to break this thing, but it needs a good cleaning.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Fri, 04 January 2013, 06:05:40 »
I used to own and sell FK-6000's side-by-side with FK-2k's. The FK-6k comes in two flavors: genuine Alps White Simplified and Knockoff Alps White identical to the later FK-2001. That's pretty much all there is to it.
Also, AFAIK the Focus is not the XM, but another knockoff. I don't know exactly who made them. They feel different from the XM's though, especially the FK-2001's.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Sun, 06 January 2013, 12:15:48 »
Use a keypuller. I only have wire ones, and they do fine.
Focus Electronic used an absurd number of different switches in their keyboards, in a Chicony-esque way. The original FK-2001 (which itself changed design) used blue complicated Alps, Type IV clones, some sort of clone alleged to be Omron, and apparently (and I don't have a reference for this) white complicated Alps (listed here: http://deskthority.net/wiki/Focus_FK-2001). I'm not 100% sure that "Type IV" is one switch — I've got an NTC keyboard that's got something most the same, and that's what I posted to the Deskthority wiki, but it's not quite the same as what Alps.tw photographed as being in the FK-2001. Hard to differentiate manufacturing differences from clone jobs. I think I've nailed down what's an APC switch due to them having a reinforcement groove in the rear contact plate leg. APC is much easier though as their switches are still in production. So are XM switches, but no-one seems to have a photo of a confirmed XM switch disassembled (e.g. Filco Zero XM, Ducky 10**XM etc) and Xiang Min's spec doesn't go into enough detail.
I know the later version with Windows keys used Type III clones — I don't have a reference for those using anything else, but it would not surprise me.
(Focus's sales mailbox is still full and still bouncing mail!!)
Bore Awards
Offline M0rph3us
« Reply #8 on: Sun, 06 January 2013, 19:32:09 »
Quite the informative thread this has been, and judging by this new board I would say that I don't particularly like Alps switches. I guess it's a personal preference thing, so I think I'm going to rehab this one some with a good cleaning and throw it up for sale. I have no clue what it's actually worth, but do people have a problem with DIN5 boards? Or do people just buy adapters to make it PS/2 and not worry?
Offline Hak Foo
« Reply #9 on: Sun, 06 January 2013, 19:59:18 »
Not really.  Some people will go straight to a USB adapter.
  • RIP
    • Boring twaddle
« Reply #10 on: Mon, 07 January 2013, 06:33:56 »
It's more complicated than that. The ones on the board quite possibly are not genuine Alps Electric switches, but copies/clones. The various copies and clones do not have the best reputation when it comes to feel!
Depends. If the board is AT, or XT/AT switchable, you can just get a cheap adapter to put a PS/2 plug on the cable. I don't think this bothers anyone. PS/2 to USB is a much bigger headache, though.
If the board is XT, which this most likely will not be, that's when you need a converter, such as Soarer's.
Bore Awards
