Author Topic: Windows 8 and Model M  (Read 2352 times)
Offline Germiphene
« on: Thu, 03 January 2013, 21:44:36 »
So I just received a Model M in the mail.  Feels great, and I'm excited to try it out, but I have a catch.  Windows 8 isn't recognizing it.  I have a ASUS sabertooth Motherboard, and on startup, I can use the keyboard to access the bios.  But as soon as I get to the log in screen, my typing is no longer recognized.  Anyone else have this problem and a solution?  I thought I'd try here first as Ya'll are the keyboard gurus! :)
HHKB pro | RF 87U | RF 87U uni-45g | CM QFR | Steelseries 6Gv2 | Filco MT2 | IBM model M | IBM SSK '87
Offline Rhinofeed
  • Formerly nathaniel_h
    • Rhinofeed
Re: Windows 8 and Model M
« Reply #1 on: Thu, 03 January 2013, 21:50:42 »
Hmm. The Sabertooth doesn't have PS/2, so you're using a USB to PS/2 adapter? If so, do you have an active or passive adapter? Maybe you need to invest in an active adapter such as the one found on ClickyKeyboards. http://rhino.im/81
Offline Germiphene
« Reply #2 on: Thu, 03 January 2013, 21:55:07 »
It is a Sabertooth, but it must be a generation before, as I'm looking at the newest model version and it doesn't have PS2.  Anyway, this MB does, and it recognizes the KB before I get to the login screen.  The num lock and caps lock initiate and glow during startup, so there's power running though the connection.  Any ideas as to why all of a sudden after the OS boots up, does the keyboard not work anymore?
Offline Rhinofeed
    • Rhinofeed
« Reply #3 on: Thu, 03 January 2013, 22:43:35 »
