Author Topic: Tips for getting used to Noppoo Choc Mini?  (Read 1336 times)
Offline NickVsYou
« on: Fri, 04 January 2013, 00:01:32 »
I purchased it recently, coming from a non-mechanical full size keyboard to a choc mini with red switches has definitely set me back, i was on the verge of returning it yesterday.
So i need your tips, honestly anything would be great right now.
Offline Firefly303
Re: Tips for getting used to Noppoo Choc Mini?
« Reply #1 on: Fri, 04 January 2013, 00:13:32 »
Had the same issue going from a rubber dome to mechanical brown switch recently. though in your case its probably a bit worse :P Red's are even lighter than browns. (you're probably use to a 55-65g actuation force, Red's are 45g)  Honestly, its really just a matter of time. Force yourself to use it for a few days and pretty soon you'll get the hang of it. If not, Red switches may not be for you.  I find that brown switches are a bit too light. if you really cant stand it you could always try something like this: https://geekhack.org/index.php?topic=38091.msg753375#msg753375
Beware though, once you get used to a mechanical keyboard, typing on a normal one feels...wrong.
Offline jeroplane
« Reply #2 on: Fri, 04 January 2013, 00:34:53 »
Is it the switches or the layout or both that's getting you? All I can say is keep at it for a few days to get used to both aspects and if you really don't like it after that then it might be time to try a new switch/layout.
I'm currently doing something similar. Moved from a TKL Filco with Blues to a 60% Poker with Ergo Clears and still getting used to both the switches and learning the function layers.
Offline NickVsYou
« Reply #3 on: Fri, 04 January 2013, 01:24:47 »
Its both i suppose, i'm a big league of legends player so the arrow keys are weird, but i'm starting to get used to it, just always making spelling errors.
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #4 on: Fri, 04 January 2013, 01:50:16 »
What do the arrow keys have to do with league o_O
Offline jeroplane
« Reply #5 on: Fri, 04 January 2013, 03:23:38 »
Was wondering this too, but maybe he uses them to scroll the screen? I've seen people do this with Dota, but I can't understand why they don't just use the mouse. Correct me if I'm wrong though, Nick!
Offline fuus
  • All Year Christmas!
« Reply #6 on: Fri, 04 January 2013, 11:52:23 »
scrolling sounds about right! Just force yourself to use it buddy, It'll happen in time!
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline NickVsYou
« Reply #7 on: Fri, 04 January 2013, 19:06:13 »
I use the arrow keys to move map, I suppose I could use the mouse.
Offline reverkiller
« Reply #8 on: Fri, 04 January 2013, 19:09:47 »
I've only ever seen pros/my friends use the mouse. Its something that's quite hard to get used to though, if you've been using the keyboard. I think that I don't like moving my right hand off the mouse, and just leave my right hand on QWER. Maybe if I could use a second layer of wasd as arrows like on my poker.... hmmm.
Offline NickVsYou
« Reply #9 on: Fri, 04 January 2013, 21:18:23 »
I have a razer naga all my spells and summoner abilities are binded to it. I'll try using the mouse movement, it sounds like it could work.
Offline Viz
« Reply #10 on: Fri, 04 January 2013, 21:37:34 »
Gl, mate!
