Author Topic: Problem with Filco ANSI  (Read 1848 times)
Offline Ballshamin
« on: Sat, 05 January 2013, 04:42:49 »
Greetings and happy new year...
I have several Filco keyboards, all of them in ISO layout (105 keys), in different languages ​​(English, German, Finnish, etc..). ISO keyboards work fine, whether connected via USB or PS/2.
I recently purchased an Filco ISO keyboard, because the combination: Cherry MX Blue + blank keys, was the only option available.
However, the keyboard has a strange behavior on my PC. If I connect it via PS/2, the keyboard just doesn't work (not recognized by BIOS and operating system). If I connect via USB, BIOS runs in "slow motion" (the keys take a while to answer), although in the operating system, it works perfectly (Windows XP).
Why does Filco keyboard has different behaviors in ANSI / ISO?
The keyboard also has other strange behaviors, for example, sometimes (connected via USB), when I start my computer, NumLock Led is on, but the keyboard doesn't respond. To get a response, I must disconnect it and reconnect.
Thank you for your help in advanced...
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Problem with Filco ANSI
« Reply #1 on: Sat, 05 January 2013, 12:41:09 »
I think is merely defective, only a coincidence it is ANSI would have nothing to do with such problems.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Sat, 05 January 2013, 13:21:08 »
Yeah, this is definitely a faulty keyboard presuming you've tried different USB ports.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #3 on: Sat, 05 January 2013, 16:56:56 »
Welcome to Geekhack!
Sorry that your first post is to report a problem (although you have a nice keyboard collection).
Make sure the cable is plugged in properly.
Try the keyboard on a different computer.
Is the Filco cable detachable?  If so, make sure it is securely plugged in (to the keyboard), and try a different cable.
It does sound a bit like a flaky USB connection, but might also be defective.
