Author Topic: Remaking Classic Keycaps for Cherry MX  (Read 23975 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Remaking Classic Keycaps for Cherry MX
« Reply #50 on: Tue, 22 January 2013, 09:51:12 »
do you think we should run an IC first? I'd go directly to the GB and place a 50 MOQ.
edit: on second thought the reason for IC might be for choosing color (I agree 1 color would be simpler)
« Last Edit: Tue, 22 January 2013, 09:55:31 by Matt3o »
Offline pasph
« Reply #51 on: Tue, 22 January 2013, 10:58:24 »
gogogogo
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #52 on: Wed, 23 January 2013, 03:15:17 »
Would you confirm this is all we need?
12258-0
(don't look at the colors/legends, just the key sizes)
Thanks
Offline DamienG
    • DamienG
« Reply #53 on: Wed, 23 January 2013, 04:22:27 »
I'd be interested in a set of these if we can get to 50 unit pricing. Not sure though how the ISO enter key works (I'd need it) as you also need a key to the left of the enter key and one down between Z and shift. You could use a blank for one of those I guess but will the angle be right?
[)amien
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #54 on: Wed, 23 January 2013, 04:38:45 »
DSA keys are all of the same profile. You can mix and match them any way you want. Only issue is ISO enter won't be spherical
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #55 on: Fri, 25 January 2013, 08:48:20 »
