Author Topic: Alps switches  (Read 10547 times)
Offline Whiskey in the Jar-o
Alps switches
« on: Fri, 28 September 2007, 07:05:52 »
According to the wiki, white Alps sliders are 'audible click' and black is 'tactile feel'. What's the feel difference between the two?  BTW, my Northgate Evolution has white ones, and they are definitely clicky, as in audible, and have a definite 'make' point that you can feel. Too bad I can't help hitting bottom after that point.
Offline iMav
  • geekhack creator/founder
Alps switches
« Reply #1 on: Fri, 28 September 2007, 09:11:24 »
I don't know...I don't own an Alps-slider-equipped keyboard.  (well, actually, I do...it just hasn't arrived yet)  :)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
Alps switches
« Reply #2 on: Fri, 28 September 2007, 11:11:10 »
The Alps white sliders used in the Northgate Omnikeys are definitely clicky. I have one 'board with pink and two with black Alps sliders, and all of them are tactile and loud. I found the same info iMav did, so who knows. I guess one of us needs to try out the other sliders to know what's up.
