Author Topic: A bundle of switches from of all colors for testing purposes?  (Read 2385 times)
Offline Aufwind
« on: Tue, 08 January 2013, 20:14:39 »
Wouldn't it be awesome if there would be a small bundle of Switches for a low fee which would allow to get a feeling of all those different switches (brown, red and so on)? Or maybe there is one and someone here could point me to it? :-) I find it hard to invest so much money without getting a chance to test the feeling of the keyboards at all...  :eek:
Regards
Aufwind
Offline khaangaaroo
Offline The_Beast
  • I like wood ಠ_๏
Re: A bundle of switches from of all colors for testing purposes?
« Reply #2 on: Tue, 08 January 2013, 20:19:23 »
Testing switches isn't the same as testing a keyboard
Offline Aufwind
« Reply #4 on: Tue, 08 January 2013, 20:32:00 »
Awesome!! I just ordered the sample kit from WASD. Thank you so much for the quick reply!
By the way, esoomenona: I love your "Portal"-Key-Caps. :D Are they self made?
Offline esoomenona
  • Gnillort?
Offline Aufwind
« Reply #6 on: Tue, 08 January 2013, 21:13:25 »
Awesome, thanks!!
« Reply #7 on: Tue, 08 January 2013, 22:01:38 »
Like Beast said, testing individual switches does not give the same experience as using a keyboard.  At the very least, try to "mount" the switches in a sheet of thin metal or plastic to give an approximation of how they would feel when mounted on a keyboard.
Offline Aufwind
« Reply #8 on: Wed, 09 January 2013, 09:12:33 »
Thank you for the hint. I will definitely try that out. :-) I am so excited about the switches, to hold them in my hands for the first time and feel what I only could read so far. :D
Offline link_tree
« Reply #9 on: Wed, 09 January 2013, 09:54:32 »
Same I recently "blindly" ordered a Filco with reds and I just can't wait to actually feel them and see what all this hype is about.
« Reply #10 on: Wed, 09 January 2013, 19:48:38 »
I have the WASD sampler kit, and also a couple of MX keychains, and although you can feel the difference in the individual switches (spring strength, tactile feedback) it is quite a different experience to actually type on a keyboard with that switch.
There was a switch sampler (kinda like a stand-alone keypad with a few different switches built into it) that was doing the rounds last year.  That would give a better indication of how the switches feel on an actual keyboard.  Maybe it will go around again.
Offline dewcorps
« Reply #11 on: Wed, 09 January 2013, 19:56:25 »
I remember that Hashbaz organized a mx numpad tester about a year ago that had all variations of mx switches soldered on. It would be awesome if we could start up one of those with mx/topres again.
