Author Topic: GH Techkeys January Pack  (Read 14435 times)
Offline martinyeah
Re: GH Techkeys January Pack
« Reply #50 on: Sat, 02 February 2013, 14:11:21 »
I just ordered
Offline TheQsanity
  • SmallFry Lovin'
« Reply #51 on: Mon, 04 February 2013, 01:45:09 »
It's Feb. Is there a Feb pack?
SmallFry! <3
Offline YoungMichael88
  • HHKB Wannabe
« Reply #52 on: Mon, 04 February 2013, 02:51:16 »
Tape trick works great. I had to use it for all my 2nd generation zinc caps from feng and the red aluminum spacebar(not the silver oddly enough). I actually needed to use two layers of green painters tape. They were pretty loose. First run were too tight, second run were too loose. If I've learned anything from Goldilocks the third run should be juuuust right.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #53 on: Mon, 04 February 2013, 08:05:27 »
Offline SmallFry
