Author Topic: Help, KBT RACE, one key has some issue  (Read 2080 times)
Offline Neo.X
« on: Sat, 12 January 2013, 11:35:12 »
All of sudden, the O key stop response. It's not completely dead though, if I keep pushing it for a while it will start working for a while, then no response again.
I think it's something with the switch and I want to get it replaced. But I don't know if I need to desolder it or not. The keyboard should be PCB mounted but with led.
Can anyone give me some help here?
Thanks
All those keyboards will be lost in time....
Re: Help, KBT RACE, one key has some issue
« Reply #1 on: Sat, 12 January 2013, 12:10:04 »
Sounds like maybe a bad solder joint? Try resoldering just that switch and see if that helps. If not, you'll have to desolder the LED and switch in order to replace it.
Offline Neo.X
« Reply #2 on: Sat, 12 January 2013, 12:12:36 »
Thanks, unfortunately, I don't have any soldering experience and tools. I was hoping that I can easily swap the switch as it PCB mounted.  :( :(
I guess it's time to learn some soldering now.
« Reply #3 on: Sat, 12 January 2013, 12:17:39 »
They now sell a soldering starter/practice kit at Radio Shack if you want to try that. Might help to get some practice on a little project board before you have at your keyboard. :)
Offline Neo.X
« Reply #4 on: Sat, 12 January 2013, 18:09:25 »
Now the O key is totally dead :'( :'( That's too bad, I do love this keyboard.
I'd like to try replace the switch, some questions I have though:
1. Can I buy a red switch from WASD and use it on Race? There is a led in the switch, I don't know if the switch from WASD will fit or not.
2. If the switch doesn't fit, can I desolder a switch from other key and replace the O key? Will desoldering damage the switch?
Thanks,
« Reply #5 on: Sat, 12 January 2013, 20:38:28 »
If you are not comfortable doing the repair yourself, you can always send it to someone to have it repaired. I'm not sure what your location is, but I will do the repair for free for you, if you'll cover the shipping both ways.
If you want to try it, then yes, you can order a red switch from WASD and replace it. The LED will be the hardest thing to desolder. You will need a 45W desoldering iron with the bulb from Radio Shack at minimum. Also pick up a 15W grounded soldering iron while you're there, and some .032 diameter rosin core solder. What you want to do is add some solder to the solder joints of the LED. Heat the joint until the solder melts, then flow a tiny bit of solder into the joint. Then you can use the desoldering iron to heat the joint and suck the solder out. If you don't do the step where you add more solder, you'll have a hard time of it. Next, desolder the solder joints of the switch. You might also have to add more solder to these as well. Once the solder pads are clean, remove the LED first. If it doesn't want to come out, you may have to apply heat with the iron to the solder joints while you pull the LED from the other side with some pliers. Once the LED is out, the switch will come off easily. Do this in reverse to install the new switch. The LED will fit in the new switch just the same as it did in the old one. Solder it, using very little solder, and you're done. Test to make sure it worked.
Edit: Just realized you said this was for a Race. The switch you will need for a Race is a PCB mount switch, but the ones WASD sells are all plate mount switches. Part number MX1A-XXNN tells you it is plate mount. It would be MX1A-XXNW for PCB mount. I can send you a red PCB mount switch if you want to attempt the repair yourself.
« Last Edit: Sat, 12 January 2013, 20:42:55 by jdcarpe »
Offline Neo.X
« Reply #6 on: Sat, 12 January 2013, 21:36:23 »
Thank you very much, jdcarpe. I just sent you an PM.
