Author Topic: Left Alt fixed with pics - CM Storm QuickFire Rapid  (Read 38131 times)
Offline Zentaaa
  • Safe Bois
Re: Left Alt fixed with pics - CM Storm QuickFire Rapid
« Reply #50 on: Fri, 30 May 2014, 10:59:25 »
omfg i love you, Been trying to do this for so long! Now my board works again :D
« Reply #51 on: Fri, 30 May 2014, 12:43:11 »
did you lift the pad as well?
I dislike soldering directly to the traces, so on mine, the switches are connected directly with jumper wire.
Offline Zentaaa
  • Safe Bois
« Reply #52 on: Fri, 30 May 2014, 12:52:14 »
I just took of the old solder and added a fresh new big blob :) if it fails again I will resort to a jumper wire!
« Reply #53 on: Fri, 30 May 2014, 13:01:45 »
Mine has jumper wires all over it (at least 7). You can see some of them in my old takeapart guide: http://geekhack.org/index.php?topic=41280.msg874636#msg874636
Offline Zentaaa
  • Safe Bois
« Reply #54 on: Fri, 30 May 2014, 13:20:21 »
Thanks for that, Hopefully I don't have to touch it again!
Offline audiosl4ve
  • Just slave
« Reply #55 on: Sat, 22 June 2019, 05:35:21 »
Thanks for tutorial, i fixed CM board with it. Works great now!  :thumb:
