Author Topic: Removing Adhesive From Caps  (Read 5362 times)
Offline MarkPharaoh
« on: Sat, 19 January 2013, 17:10:46 »
Hey, just got a set of KBC PBTs in the mail, but while pulling them off of the Styrofoam backing they had a good amount of adhesive on the bottom of them.
What do you think is the best way to remove the adhesive?
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Removing Adhesive From Caps
« Reply #1 on: Sat, 19 January 2013, 17:22:22 »
Warm soapy water?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #2 on: Sat, 19 January 2013, 17:27:42 »
Isopropanol (alcohol) or petroleum ether (lighter benzine)
« Last Edit: Sun, 20 January 2013, 02:26:06 by TheSoulhunter »
A Ghost From The Past
Offline MarkPharaoh
« Reply #3 on: Sat, 19 January 2013, 18:02:11 »
Soaked them in water and scrubbed at them with a nail filer. They're better but still very sticky. Rather annoying, but it doesn't affect the actual typing so whatever.
Offline cactux
  • Topre Knight
« Reply #4 on: Sat, 19 January 2013, 18:08:18 »
Acetone
[FS]☠ The temple lol ->HERE<-
« Reply #5 on: Sat, 19 January 2013, 18:35:26 »
Naptha (old-fashioned cigarette lighter fluid) but be careful with it and wash with soapy water immediately afterward. This is best for getting most adhesives (eg price tags) off most everything, but, be warned, it can damage paint and some plastics.
Citrus oil based organic solvents work well, sometimes, too.
- D Trump 2026-10-24
Offline MarkPharaoh
« Reply #6 on: Sat, 19 January 2013, 18:46:18 »
Thanks for the info everyone, will hit the store sometime soon because between the adhesive and the spacebar being bent it's actually sticking on presses xD
Offline jabar
« Reply #7 on: Sat, 19 January 2013, 21:52:27 »
Acetone
You should probably substantiate that that acetone messes ABS keycaps up, chief.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline kmiller8
« Reply #8 on: Sat, 19 January 2013, 21:54:07 »
These are PBT ;)
Offline jabar
« Reply #9 on: Sat, 19 January 2013, 21:54:27 »
These are PBT ;)
I know, in case someone else gets a bad idea concerning their ABS keys.
Phantom 7bit
Offline AKIMbO
  • HHKBro
« Reply #10 on: Sat, 19 January 2013, 23:29:37 »
WD40....I use it on old IBM boards all the time.  Coat the residue in WD40 and let it sit for 10 minutes.  Then wipe it off with some soapy water.
| KBD75 (box reds)
Offline terran5992
  • One With The Cup Rubber
« Reply #11 on: Sun, 20 January 2013, 02:27:33 »
Uppp, currently facing this problem as well , what I am doing us using my fingernails to scrape off the residue , don't know how much longer I can endure , this is a 104 set.
Offline terran5992
« Reply #12 on: Sun, 20 January 2013, 05:37:27 »
Foud the cure to this problem,
Scotch Tape.
Able to get rid of the adhesive effortlessly
« Reply #13 on: Sun, 20 January 2013, 11:44:34 »
Tape can be the easiest way, if your tape and the the residue are of similar composition. Also, it usually only works if the residue is fairly fresh.
Often, it seems to me that old keyboards have old residue on them, and that is the hardest to remove.
A chemist once told me that it is easy to get an adhesive to stick, but it is much harder to get it to stick and release. And, over time, some turn to dust, while others become ferocious and etch themselves into the surface.
Offline JoeC
« Reply #14 on: Sun, 20 January 2013, 20:16:11 »
Citrus based cleaners CAN and most likely WILL discolor plastics. Especially after exposure to sunlight.  Please use caution.  I like acetone, though it is also dangerous to use, but perhaps less so.  Another thing to use is charcoal lighter fluid (yep, the stuff you use at the company picnic bbq).  I still like to test it for color safety.  Be careful with flammable liquids, please.  Fire in designated location = good... fire in your keyboard = bad.
Lurk Moar!!!!!
Offline deltr
« Reply #15 on: Mon, 21 January 2013, 09:37:05 »
These are PBT ;)
I ended up in this thread from seeking ideas to remove the lettering from the keys on my CM Storm QF (ABS), do you just saved me some trouble!
