Author Topic: 1st gen MacBook re-application of thermal paste.  (Read 9994 times)
Offline iMav
  • geekhack creator/founder
« on: Sat, 03 November 2007, 07:30:46 »
I posted this a while ago on another (now defunct) forum site.  Just throwing it up here for preservation (and for those that might find it interesting).
Before pics and measurements.  This was all performed in a climate-controlled room (A/C) at 75 F.
Idle after 15 minutes:
pic1, pic2, pic3, pic4, pic5
Idle after 30 minutes:
Max temp at full CPU utilization (both cores ala two instances of "yes > /dev/null"):
pic1
Stabalized temp at full CPU utilization once fans kick in and do their job:
pic1, pic2, pic3, pic4, pic5, pic6
Stabilized idle temp after 100% CPU test was completed:
pic1
AFTER photos/measurements.
pic1
pic1
Miscellaneous additional pics:
Thermal grease on the heat sink (sorry, these are a bit blurry):
pic1, pic2, pic3
Thermal grease on the CPU and GPU:
pic1
Fresh coat of AS5!
pic1
Clean heatsink:
pic1
